A couple of horses found (in the throttle body)
#31
Originally Posted by David Floyd
Ok... I feel stupid, I just replaced my crumbled up o-rings and I can't quite figure out how the coil spring goes back on
would someone please post a picture of the spring area.
Thanks,
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Thanks,
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#38
Funny, I just replaced my o-rings today!
I used a small steel rod which had a sharp pointed end. With that I "destroyed" the old seals so that I could pry up the pieces from the grooves.
If you have problem getting pictures of the spring just PM me an email adress, my intake is still on the garage floor.
Tomas
Tomas
#40
Can someone help me with the thin washers on the shaft. I'm trying to figure out how many I should have and where they go. I got the reseal kit. The instructions say there should be a thin washer under the TPS that must be removed in order to get the snap ring off the shaft. When I removed my TPS, I found no washer under it. So, I removed the snap ring, and pulled out the shaft. When handling the throttle body, an extra thin washer fell out. I'm thinking that washer was under the snap ring. Anyone else find a similar arrangement when they dissassembled?
I now have three washers -- the serrated one that does under the nut on the end of the shaft, and two flat thin washers, one slightly bigger than the other. I can't quite tell where the washers go, but I suspect the smaller one goes under the snap ring on the TPS end. Yes? No?
#42
Originally Posted by MichelleJD
Yes. I only had one washer and it was under the snap ring. Rebuilt mine yesterday ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
#43
Hey Tom
I hope your planning on posting this write up on your website ?
I have the distinct impression that I will be following suit shortly
Regards
Ed
Regards
Ed
