Which EBC
Old 08-12-2004 | 06:32 AM
UK952's Avatar
UK952
Question Which EBC
Following on from MBC vs EBC which EBC offers best performance / $ for use with a DPW?
Tony
Old 08-12-2004 | 07:36 AM
special tool's Avatar
special tool
I had an HKS evc - thing pissed me off so much I ran it over with my dump truck - then I backed over it. The $60 Lindsey dial works beautifully and consistently with my Tial.
Old 08-12-2004 | 10:24 AM
Adam H's Avatar
Adam H
For an EBC, I would go GReddy PRofec B or PRofec B Spec II.
Old 08-12-2004 | 11:06 AM
MySwiss's Avatar
MySwiss
If you can pick up a Used or new Profec B spec 1, you won't regret it. It's so user friendly , fast and accurate. I'm now using the Profec B spec 2 , with all the bells and whisles, and I wish I still had the Profec B spec 1 .
Old 08-12-2004 | 09:46 PM
MichelleJD's Avatar
MichelleJD
Jane Bond 007
Is it okay to buy these things used?
Old 08-12-2004 | 11:16 PM
SamGrant951's Avatar
SamGrant951
More than likely yes Michelle, I however bought a HKS EVC 3 and the damn solenoid was shot. Scott H messed with it for awhile, but he said it sucks as well. So now Im stuck with something that doesnt work and I feel bad reselling on ebay and acting like I never installed it...
I bought my MBC used, and it works great! After riding in Dan87951's car I can say the Greddy Profec B seems very easy to use and does what it says, nothing more nothing less. I would get one of those or a Blitz SBCid.
Old 08-13-2004 | 10:46 AM
UK952's Avatar
UK952
Thanks for the advice so far,
I have also found a boost controller comparison here http://www.sportcompactcarweb.com/te..._boostcontrol/
With an EBC will both ports on the tial get used?
Tony
Old 08-13-2004 | 11:38 AM
SamGrant951
Tony
Yes, there is a switch on the back of most controllers, for single or dual port mode.
Old 08-14-2004 | 02:45 PM
UK952's Avatar
UK952
Thanks for all the advice Greddy Profec B spec 1 looks like the one to look for is $299.00new a good price?
Tony
Old 08-14-2004 | 03:32 PM
v944god's Avatar
v944god
I say APEXi AVC-R, with a tial wg.
Old 08-14-2004 | 07:43 PM
UK952's Avatar
UK952
V944god any particular reason why?
Old 08-15-2004 | 05:40 PM
Danno's Avatar
Danno
"I say APEXi AVC-R, with a tial wg."
I'd say that too with dual-solenoids in push-pull configuration.
"V944god any particular reason why?"
Maximum performance. You can customize boost on a per-gear basis. Large-turbo, high-HP cars can use lower boost in 1st & 2nd gears to prevent loss of traction. You can customize boost in those gears to give maximum-acceleration at the limit of your tires to get maximum perfomance.
Then you can also customize your boost-curve on an RPM-basis as well. Typically good to lower boost a tiny bit in an 1000rpm range around the torque peak to lower wheel-spin. Then rise it up 1-2psi as RPM increases after the torque-peak to combat the kamikazi drop in the torque-curve. Essentially, you're varying boost to combat the changes in the engine's VE at various RPMs.
Old 08-15-2004 | 05:43 PM
Matt H's Avatar
Matt H
I have an AVC-R as well. Havent run it yet, but will be soon enough. Danno, I would love any info on running dual solenoid setup, dont think I have ever seen that but it sound like it would be a good idea.
Sam - you should be able to just buy a solenoid. Call any of the Japanese car tuners, shouldnt be much.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-15-2004 | 05:59 PM
azmi951's Avatar
azmi951
Just got my Blitz SBC id will install shortly.
It was the SBC id or the AVC-R
I like the blitz because of the simplicity of install and the featrues. also a remote display.
Old 08-25-2004 | 02:22 PM
MichelleJD's Avatar
MichelleJD
Jane Bond 007
Given the choice between the Greddy and Apexi units, which would you guys say is better? I'd be running a TiAl wastegate and Greddy BOV.
Quick Reply: Which EBC
