test pipe install gasket question
I'm going to be installing a used Bursch test pipe I got from another Rennlister on an otherwise stock exhaust. I wanted to have new gaskets at the ready... is there an alternative to the $36 a piece price that the local dealer charges for these little pups? Any tips appreciated, thanks much. kie
Sure is. NAPA carries it. It's a sheet of exhaust gasket material that is exceptiional stuff. All you have to do is trace the mating surface and cut it out with tin snips. Scissors won't work as the stuff is really sturdy........
Victor Reinz (manufacturer)
JU 222 (manufacturer's PN)
Also works well in a bind if you don't have any of the exhaust sealing rings. It's a 12" X 36" sheet and I think it cost me $8 so it'll last you a long time.
The NAPA p/n is JV 222 not JU. Stuff works great - I use snips and a hole punch (7/16) to make my gaskets.
Vic
If you're looking for the 3" triangular 3-hole gasket that goes between the downpipe and the catalytic section, you can use a header-gasket for American hot-rods. Find them at Pep Boys for $1.65 each or so. They're heat-resistant fibre gaskets with a 3" steel compression ring in the middle. The only thing you'll need to do is mark two of the holes by placing the gasket on the flange and tracing the outline. Then cut out the new holes with an Xacto knife or something. Cyrus951 did this very job last weekend.
Then for the square gasket between the catalytic and cat-back section, you can find another header gasket with 3" compression-ring, but this time with a square 4-bolt pattern. Kiss another $1.98 goodbye!
Thanks for the tips. I used the NAPA stuff and it worked well. I must say that for those of us without emissions concerns this has to be the best valued upgrade by a longshot. $150 for a used test pipe and $11 for gasket material. More boost and so much quicker spool-up... plus the car must have lost 25 pounds and it sounds better as well.
Sorry all but just checking out what this test pipe is? Is it a cat replacement pipe?
I have never heard this term in UK (As Winston Churchill used to say Britain and USA, 2 great countries divided by one language!!!)
Has anybody got another one for sale. or where can I get one reasonably?
cheers
Tom
cheers
Tom
cheers
Tom
cheers
Tom
