turbo blowing oil?
I never notice, anyway
well, i pulled off the turbo->IC hardpipe. looks like castrol had a party in there. i can't believe how much oil is in there. time for a new turbo!
ibdavid, you have a PM. i need a k26/6, used is ok. anyone?
Might want to do a leakdown test or at a minimum a compression check, worn rings can cause excessive blow-by pressurizing the crank, blowing oil thru the oil/air separator into the intake.
Depending on your milage it could be a combination of both rings and turbo.
But a quick leakdown will tell you.
Have you ever poured a quart of oil from the intercooler and a pool of oil in the compressor housing?? I have, and the turbo was in perfect shape.
So check that intercooler for a mess.
yeah, they blow some oil is the key. i always used to have a little bit of oil in my hardpipes. but now its literally pooling in there.
peckster- whats a plug chop?
