Clutch Pedal stays down occasionally.
This is sort of part II to the intermittent clutch slipping saga. Since the throw-out bearing is getting stuck on the throw-out bearing guide, is it possible that if the thro-out bearing does not return that the clutch pedal could stay at the floor? I'm pretty sure that most of the time I had clutch slippage the pedal did stay at the floor, but not 100% that was the case. I know the usual suspect for pedal staying at the floor is air in the system but...
Mike G.
Mike G.
I guess I should have added that I need to physically pull the pedal back up with a bit for force. Almost like it was suctioned to the floor. It's definitely not an oiling the pivot issue. Wish it was tho. haha
Mike G.
Mike G.
Appreciate the response but the the slave is new and the fluid level is high. and so am I, haha. I also bled it 10 times. I'm trying to find out if the clutch slave cylinder doesn't retract from the clutch diaphragm fingers if the pedal would stay on the floor. But I'm guessing I'm not going to get that answer until I put something together and try it myself.
Mike G.
Mike G.
Mike G.
Mike G.
A sticking clutch pedal can also be caused by a grove being worn into the clutch pedal pin. Here's an old thread discussing a similar issue.
Post #16 describes the pedal pin issue I've seen and then the discussion turns to a cracked firewall and repair.
Good luck.
https://rennlist.com/forums/924-931-...g-noise-2.html
Good luck.
mj951,
Thanks. That thread makes me think I have a broken pedal return spring. But that leads me into another question. Currently my clutch hydraulic system is dissembled, no fluid no lines no nothing. SHOULD the clutch pedal return to the normal up position when depressed to the floor? I'm guessing yes lol. Oh and by the way the pedal snaps to the floor and then needs a good bit of effort to return it to the normal up position. Scheisse!! Too many things bad happening simultaneously.
Found my answer over on the Pelican forum site. The clutch pedal will stay down if the hydraulic system is open. So looks like its time for a new master clutch cylinder also. Weeeee
Mike G.
Mike G.
mj951 (01-18-2024)
I had that exact same problem when I picked up my new-to-me 951. I drove it from Kansas City to Nashville with the pedal stuck halfway (I didn’t know better) and couldn’t figure out why the cruise control wouldn’t work. Until in rush hour traffic I heard a “thunk!” and found my clutch pedal fully out! Things worked perfectly the rest of the way home and I had cruise control again! I researched Rennlist and replaced both master & slave cylinders and the clutch engages right in the middle of travel and no more sticking. Hopefully that’ll solve your issues too.
Golden Hands (02-05-2024)
