Coolant reservoir
Coolant reservoir
Came home after a drive to see my coolant tank is shooting coolant out under pressure at the seam.
Anyone have one laying around for sale?
I'm in Mishawaka, In 46544. will cover shipping as well.
And is Lindseys fancy one the best option next?
Thefu
That ("Lindseys fancy one") looks like the old Huntley Racing design. The sight glass was reportedly problematic for leaks. I must have missed something as there is no way to add this to your cart, nor see a price. IOW, it may not be available...
Has anyone used a non turbo tank and like T'd off the single outlet?
I'm assuming the difference is the outlet for the aux pump.. i could be wrong.
600$ seems outrageous for a tank
Something could probably be rigged but be aware there is a flow check device in the upper spigot on the tank.
I can't find the URO one for a turbo.
I'm also wondering whether one could you hydrogen peroxide or bleach to make the yellowed plastic white again... even though that's not the issue for OP atm.
Hey Nicky, did you still need a coolant tank? I replaced mine recently because I got a deal on a newer one, so my (probably OEM) old tank was still functional when it was removed.
