Pushing only 12psi of boost..
Now that my gauge came back from autometer, I've had the privelege to get some correct readings. In 2nd and 3rd gears, I get a max boost of only 12psi (under full throttle) Is this normal? What are the normal boost numbers under 2nd and 3rd?
Also, in 1st, I opened full throttle, and near the redline, the factory "!" idiot light flashed, then went off. Is this the overboost protection?
And, what should the gauge read when idling? (mine reads -10)
Thanks.
Thanks.
Idling should run between -16 to -20. At what rpm is the idle when warm?
-10 is definitely too low, could be a vacuum leak. Make sure the gauge is properly installed, check the back and see if the nylon tube is fully in.
Re: Pushing only 12psi of boost..
Thanks.
Thanks.
UAE Rennlist Ambassador
If you had CHIPPED the car, then you should read somewhat over 12psi, more like 15~16psi in the range........stock is 11psi (if my memory serves me right).
That is what i recon. Coz from 86~87 Porsche used a KKK26/6 Turbocharger and a single port wastegate (i think). But from 88+ The turbo was upgraded (changed) from a KKK26/6 to a KKK27/6 (larger compressor housing) along with a dual port wastegate. Boost pressure was kept the same (i think) but because of the changes made to the turbocharger and wastegate, more power was generated. Im saying single port and dual port wastegates because i know that there are differences, it may not be exactly what i meant by dual port, but there ARE differences.
Monkeys Removed by Request
pretty much exactly what Tom said. The k27 was never used on 944turbo's. The 88 turbo S and 89 car's did use a larger hot side(turbine ....NOT COMPRESSOR) which was 8 instead of 6. All 944 turbo's use a single port wastegate.
11psi is completely normal for a stock 89 car. The light going off could be alot of things. Is it just this light or do any other's go off as well(the emergency light go's off along with the oil light to tell you that it's oil) If the car is running normal and pull's it's prolly not a big deal. If you HG reading is only 10 then you DO have a vac. leak someone. Make sure as people already said that your new gauge is infact installed correctly and then start checking line's one by one. Unfortunately there are a ton of them so this might take a little while. Goodluck.
"On an 89 turbo the stock is only 11psi?"
Yup, from the manual, it says that anywhere between 9-12psi is normal for these cars stock. The non-S Turbos start dropping boost at around 4500rpm while the TurboS hangs onto max-boost a little longer and doesn't drop until 5800rpm or so. They end up at around 7-9psi by redline.
Also max-boost will typically be lower in the lower gears with the highest boost levels generated in 4th & 5th gears.
Sorry, i knew that but got the numbers mixed up (i knew i messed up some where) Are you SURE the wastegates are the same? maybe not DUAL PORT like i meant, but there are differences right? either in mounting position or something....
Haven't noticed any differences in the wastegates. The TurboCup cars did have a wastegate with a narrower body, but the spring-rates and valve sizes used were the same. And they were all single-port wastegates.
