GTech graphs...0-60@5.2 sec edit:correction 5.7sec
Here are some before and after Gtech Graphs. One is HP the other is a 0-60. These are under the same conditions, same road and several runs were performed with very repeatable results. The 0-60 wasnt overly hard with no wheelspin or slipping the clutch. Other than the items in the sig I have gutted the cat and am just kissing 16psi falling off to 12-13 at redline.
The lower readings are with stock chips and a reliaboost kissing 13 psi falling to 10 at redline.
Originally posted by rcatherton
The chart shows the car is doing 4 mph at the start and the shift points are up on the higher H.P. run.
And you have to remember that above 60mph air resistance really makes the HP reading show lower than on a dyno. And the shift points are higher cuz the chips raised the rev limiter.
But is great as a before and after.
I just checked with G-Tech and 5.2 sec is the true 0-60. The software includes the rollout time for time calculations and after looking at the plots I see that it does.
Cool.
Cool.
I have not had the weather (dry) to test my car with my G-Tech Pro. I want to do a test with my stock PD's, stock rubber size. Then I am switching to my new 17" Fikse with S-03's, 245 & 265. It will be nice to get dry weather. It would be too much to ask for weather above 50 degrees.
5.2 seems quick for 233hp. Could there be other factors?
Tony you are correct. A stiffer suspension will show your Gtech results to go down.
Although, 0-60 is all about traction.
I ran a 4.55 0-60 on the GTech with these mods:
- Gutted Stock cat and muffler
- APE Chips @ 19 psi
- Beru Plugs and Magnecore wires
-LBE
But these Traction factors:
- Cup Clutch
- 10" Nitto 555R's
- LSD Tranny
- Gear Changes were .15 seconds from the time the clutch was depressed to the time is was let out and engaged.
Although the average was about 4.7. I consider myself pretty damn good at launching. That 4.55 time I slipped the clutch just enough to keep it just at the limit of adhesion for the initial launch. I was running 10 Inch back rubber that would hook up very well if you knew how to feather it. The 1/4 time on that run was 13.1. The Gtech has been dead on with every one of my friends to use it. My car was the only one to get a surprisingly good time.
-LBE
- Cup Clutch
- 10" Nitto 555R's
- LSD Tranny
Originally posted by Tony
Rear end squat, the down fall accuracy wise of accelerometers. The tipping aft of the device induces a false acceleration.
I do several runs on the same road in opposite directions and I will only see 10 HP and 10 TQ variances.
Sometime I want to head to a dyno and compare.
When stock I was doing good to get 0-60 in 6.8 sec.
The day I did these runs I did 3 , each trying a harder launch
I did a 5.6. a 5.4 then this 5.2
Sorry I missed this thread... Is that wheel HP OR Flywheel? Streckfu mentioned the correlation b/t time & HP- the stock Turbo S rana 5.5 & it had 247/258 flywheel- I DO think the Turbo S's seem to show better on the dyno compared tpo normal turbo's- I mean that the dif b/t the two cars seems to be more pronounced on the dynos than the factory flywheel ratings would show- anyway, I ran a 6.1 w/my turbo S & a 1/4 opf 14.6 @ 101.9 w/a regular G-tech- I'm aware there are many variables w/those things, but, my G-Tech has proven to be VERY accurate- although the speeds at the 1/4 tend to be a little high, BUT, they say that's b/c the G-Tech shows the actual speed, whereas the tracks take an average of the last 100ft or something like that(?). Anyway, on my ONE run, I gave it a really gentle launch & shifted very carefully, so, I'm very convinced the car could run a 5.5/14.2 bone stock like the magazine's showed. The cars really need a good bit of wheel spin to keep from bogging down & wasting time- of course, TOO MUCH wheel spin will slow you down, but, I've found that spinning close to half way through 1st is about right, but, it's controlled spinning- an extra 100HP would probably make this an excersise in futitlity though- would probably just burn the tires off too much & get nowhere- I've noticed that w/stock HP levels, the cars will really throw your *** into the seat & keep going hard, even while spinning- the LSD is on 40% lock, which is a lot for a street car- many BMW's of the era were on 20%.
Anyone ever check their BRAKING distances? I would love to hear a few of those- I'm going to check mine again w/new tires & 17" wheels, as soon as I get my susp sorted out.... I was getting ~122ft, from 60mph, & was not very happy w/that...
Its rear wheel but it also includes wind and road drag.
I found a site which calculated HP losses at various speeds
taking into account the CD and frontal area.
here is a .jpg with that loss drawn in on the Gtech graph
showing aprox RWHP without aero losses.
