What Metal are M030 Spindles?
Old 03-12-2021, 08:55 PM
  #31
joseph mitro
joseph mitro's Avatar
what about cryo freezing the spindles for strength? anyone ever done that?
Old 03-13-2021, 12:40 PM
  #32
Droops83
Droops83's Avatar
Originally Posted by s85b50
Does anyone know the ball joint pin size for M030 spindles? Looking at control arms with 17mm pins..
M030 has 17mm bores like any other 944 spindle.
SeaCay (03-13-2021)
Old 02-18-2022, 07:27 PM
  #33
964-C2
964-C2's Avatar
What are your thoghts about cutting - shortening -welding the steering arms on the spindle (I understand some are doing this for faster steering). Can it be done in a safe way.....?
Old 02-18-2022, 08:36 PM
  #34
Mike Goebel
Mike Goebel's Avatar
I would imagine if you shorten the arms it would only slow down the steering. Give it a think!
Mike G.
Old 02-21-2022, 04:13 PM
  #35
floatingkiwi
floatingkiwi's Avatar
regarding the ball joint pins - use high strung 944 arms instead of the other types. They've got a standard sized pin and seem to be holding up well to track work.
Old 02-23-2022, 02:22 PM
  #36
964-C2
964-C2's Avatar
Mike G.
No. Shorter arm will give faster steering. But I am not sure if cutting/welding the arms could be done in a safe way...
Old 02-23-2022, 02:45 PM
  #37
Mike Goebel
You are correct. I guess I had too many beers that night! The loads probably are not that high at that joint but.... steering is not something you want to lose control of. I guess if a sleeve could be added to the weld joint so that the joint is not purely relying on a butt weld you'd probably be ok. Tie rod angle will be changing too. I wouldn't do it but I do find the slow lock to lock ratio of the 944 steering annoying too.
Mike G.
Old 02-24-2022, 10:57 AM
  #38
FrenchToast
FrenchToast's Avatar
No.
The spindle setup isn't something I would call reliable these days. Cutting and welding is asking for trouble.
Old 03-05-2022, 06:23 PM
  #39
964-C2
964-C2's Avatar
Originally Posted by FrenchToast
No.
Looks like some are welding (on) them at least.
https://www.9tfe.co.uk/
Old 03-05-2022, 08:12 PM
  #40
Gage
Gage's Avatar
That looks like some back yard engineering... and mig welding. No thank you.
Quick Reply: What Metal are M030 Spindles?
