tranny removal help...
I have an '86 951 parts car that I bought for the LSD tranny. Last night, I finally got around to working on the tranny removal, and everything went along fine except that I can't get the darned coupling sleeve loose. The bolts holding the sleeve are out, and nothing looks wrong or different, but I have had very little luck in moving it in either direction. I have removed all the other tranny mount bolts and figured I could lower it on my tranny jack and get it to release/come apart, but its holding fast.
Its supposed to slide towards the transaxle and release on the torque tube side, right? Any suggestions, short of taking a sawzall to it?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Regards,
Originally posted by Sam Lin
You can spray the splines with PB Blaster or Kroil as well, and tap on it with a hammer, before the large screwdriver prybar technique.
Sam
Sam
IIRC, you're better off keeping the tranny bolted to the housing - otherwise all the weight is hanging on that coupler and it ain't going to come apart. Should come off "fairly" easily then. I was lucky enough to be able to pull it back by hand, others have required more ... persuasion.
I tried both bolted together and then disconnected it after I had no luck... thanks for the suggestions, I will hose it down with PB first and go from there. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Regards,
I would keep at least 2 of the 4 main bolts in while you try this, just to take a little bit of the stress of the input shaft.....
When taking out the transmission that coupler is normally the 2nd thing I disconnect.....
