Wastegate Options
Suggestions on a new wastegate?
I have seen recommendations on Deltagates, Tial 38's, Guru single prot and Lindsay stock replacement single and dual port designs.
Car has a profec B controller, AA Stage 2.7 chips and a new Max Flo turbo benig installed right now.
My old wastegate appears to be OK but I am trying to think ahead.
Thanks -
Mark
Thanks -
Mark
Sam lin is right get a tial 38mm with a 9lbs spring or higher, with your'e pro- fec b your'e boost should be comming on fast.
MY swiss has a good price on the tial wg.
Even if your stock wastegate "seems" ok, I bet your car will liven up with a new wastegate. My car felt fine (with a Profec B), but I could not get more than 280 or so HP out of it. Adding a Deltagate made the boost hit much harder (with the same Profec B set the same way), and netted me 25hp. The Deltagate is fine, by the way, but next time I will go with Tial.
UAE Rennlist Ambassador
So you guys are saying that a Tail 38mm wastegate with 1.0bar sprinig is better and safer than a Lindsey dual port or a stock shimmed? both of which have boost controllers? My stock 951 is in need of a new wastegate, a tial 38mm with 0.9 or 1.0bar spring will be fine?
