On installing my pressure plate, I snapped one of my bolts off. It was the last one, all others were torqued down. Was able to remove the rest. It won't come off with vice grips. They were new bolts. I think it bottomed out in the back of the hole, and my torque wrench wasnt working properly. Options to remove, should I take flywheel off and have a welder try the weld a nut trick? There is about half an inch sticking out.
Regardless of the method to remove the broken stub, it'll probably be easier with the flywheel out of the car.
The welding trick is a great one, it'll heat things up in addition to providing traction. Heat is your friend!
Weird that you can't get it with vice grips, since it's new. Maybe file flat spots on the sides to get a better grip? Are they factory bolts -- not sure how you could have bottomed it out? With half an inch sticking out, welding a nut on should work well. Honestly, I'd probably pull it out of the car and try welding it first (since I have welders handy). The last thing you want to do is chew up the stub to the point where you'll need to drill... (hmmm, maybe that's second to last after screwing up the flywheel itself....). Just don't use a hardened steel EZ-Out in there -- it can snap off and make everything worse...
Not sure if it was a factory bolt, ordered them from pelican or paragon can't remember. Using a kep pressure plate, and had the flywheel surfaced, maybe that combination was enough to make a bolt too long for a hole. It didn't really snap, just twisted and broke right before it was torqued.
Post a picture of the bolt if you can. I once got the wrong PP bolts from Paragon. When I called them on it, they were embarrassed and said their supplier made the switch without telling them -- and it went unnoticed until I discovered it. They overnighted factory bolts, and were great about it, so no complaints there. But, if you got yours from that batch, it might explain why they weren't right. I'd triple check they are right before buttoning it all back up. Better now than after everything is together...
1/2" sticking out should give you enough to grind 2 flat spots opposite each other and remove with an open-ended wrench.
If that doesn't work, you'll still have enough bolt to weld a nut onto.
I was able to get a better grip on it with vice grips, it was pretty hard to turn out though. Are pressure plate bolts and CV bolts the same? I may go to the local fastener place and see if they have some 8.8 bolts. I think my torque wrench wasnt working properly and over torqued them.
You are not going to find the proper bolt at your local hardware store. It is a 12 point triple square head with the head being about half the height of an allen (cheesehead) bolt. I don't know the hardness.
Does it really matter if it's cheese head or Allen head? The ones I removed when I pulled the clutch were allen head. I think the only difference between the na bolts that I have and the 951 ones are the head.
The turbo bolts have a thinner/shorter head. That's the key....
