Oil pan gasket - what should I consider at the same time?
About to do the dreaded oil pan gasket with stock cross-over pipe and subframe. With everything that will be apart - top and bottom - what are other good upgrades/maintenance items to do at the same time? Car is being prepped for track use.
You could go down a deep rabbit hole with this, but removing the oil pan is a big enough job on it's own that I personally didn't do anything extra other than these things^.
You'll have the steering rack and control arms removed, and you'll probably have to get an alignment done afterwards. So you might want to think about tie rods, steering rack bushings, control arm bushings etc.
You'll also be pretty close to having the turbo out. IIRC I had to remove various bits of plumbing from the turbo to access the crossover bolts, so it might be a good time to remove/inspect/rebuild the turbo. If you do that, then replace the air-oil separator seals since that can only be done with the turbo out.
I would recommend you install a three piece crossmember from Lindsey Racing ... it makes replacing rod bearings a lot easier and you don't
need an alignment every time , unlike with a OEM one piece unit which has to be removed to drop the oil pan !
With a three piece unit , you only need to remove the center section and your suspension settings stay intact.
this is a clear concern as the budget could easily jump multiple grand, depending on what I choose to attack. i am considering the turbo, but then i'd likely consider a larger exhaust, a new wastegate, and likely new software. the access makes you want to take advantage of the timing, but that's a dangerous thing.
any direct experience here with the 3pc subframe? longevity?
considered the 2pc exhaust crossover pipe, but they only modify supplied pipes. i'd have to inquire on the turnaround time on that.
Mike,
The only isue i've had in five years of racing is some slight rubbing on the oil pan from the left side of the three
piece crossmember ... i had to grind down one of the corners for clearance , but other than that i'm completely satisfied , it makes
the yearly rod bearing change a piece of cake !
I can assure you that the Lindsey Racing crossmember is a solid piece , just like most of the stuff from Lindsey Racing , it's high quality !
Over the years i've sourced a lot of parts from Mike and Dave and i've been completely satisfied.
Cheers
Phil
Cheers
Phil
My three piece cross over is a fantastic piece of work. Never had any issues with it.
As with anything on cars it just needs to be installed properly. I feel like sometimes the mechanical failures of products is usually the fault of the installer not the products providing a part is a quality piece which the 3 piece cross over is very good.
