Where to get stock DME chip?
I would like to get a stock chip to replace my autothority performance chip with the hopes it will help me pass smog.
where can I get one of these?
What year is your car? '88TS and '89s used a 28 pin chip. Earlier cars had 26 pins.
I have a stock 28 pin chip you can borrow if you want to pay shipping. I'm sure others have chips stashed away as well.
If you have an 87 model year car you need to find out if you have a 24 or 28 pin DME. Open it up and count the pins. You should probably open the KLR and see what's in there. Performance chips for the 951 typically come as a set. If you go back to stock then you need to make sure they're both stock configuration.
If you have access to a EPROM programmer you can download stock chip images for both 24 and 28 pin DME chips from Joshua's old DIY Tuning Tools web page. They are inside the 951 Bundle.zip file.
http://roguetuning.com/diy_free_944_tuning_tools
Markl951 - epic thank you for that information. I will open up both the KLR and DME and start counting pins. Do you know what to look for in the KLR?
Paul Waterloo - thanks for reaching out. I have a potential lead on chip set and will reach out if it does not work out.
markl951 - Thank you so much for that information! I opened up the KLR and sure enough there was a performance chip in there too.
For others:
Here is a link to KLR DME removal process by Lindsey Racing: https://www.lindseyracing.com/LR/Parts/CHIPCHANGE.html
Here are a couple pictures to help identify what to look for:
Chip inside DME (24 pin on 1987 944 turbo)
Chip inside KLR (one with white label)
For others:
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/autothority_chip_507dcd0285289ab0e3e7aa9549e172d88aab86a8.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/klr_1_49e0ef9cfee4719ab1ef3c5d7016f1d87c7ecd90.jpg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/klr_2_616c0f0e8addd3c6a7844f95e28f089b2fdcf4d5.jpg)
