castrol 10w-60 "supercar" oil?
has anyone used this in their 951? was doing a little reading, have seen some 911,996 turbo use. It's the Same as BMW M oil.
reading on BITOG they say it shears down to a 50wt after about 100mi.
Discuss:
Discuss:
I use this since 2005 in my 951 and I pleased with it. Back then it was sold as Castrol RS 10w60. Now I'am rebuilding my engine and I plan to use it again.
This is a “opening a can of works” topic. However I believe no matter the oil any of us use the biggest issue is changing the oil(s) in our cars more frequently then suggested by any manufacturer. Over 60% of engine failures have to do with oil breaking down from aeration (oxidizing) due to the crankshaft acting as an egg beater. The higher the RPM’s the engine runs at the more often the oil should be changed. If you track your car I suggest changing it after every event. For the repurposer’s, you could use the old oil as bar oil for a chainsaw or equivalent. Even clean looking oil can be broken down due to being aerated so I recommend not going off “it looks good” kind of thinking. If you live in a cold environment I would stick to thinner oil and higher temp area’s thicker oil. Also adding oil coolers help keep oil cooler(hence their part name) so it does cut back on oil thermal break down but not aeration. A dry sump system helps with aeration issues but cost a lot. If you track it all the time I would recommend a dry sump and oil cooler. If you ever get into the engine and have the rods out Michael Mount has a “rod mod” service only he personally provides which replaces the stock Glyco bearings with harder nascar style bearings that are 75% as wide which I believe helps due to not having the oil heat up as fast because it spends less time under the surface of the rod bearing. So as for the Castrol 10w60? If you live in a warmer area then run it. Just never use a Fram oil filter. And MOBIL 1 oil filters work too good and could starve the engine if it’s not installed on a engine that’s clean inside.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Heat is why we need heavy oils.....if you don't track your car its not as big of an issue. If you do track your car without an oil temp gauge you are blissfully unaware of the extreme temps!! Stock 944 turbos can get well over 250f oil temps on the track.
I get that, but heavier oil actually holds more heat and cannot shed heat as quickly as thinner oil. So while heavier oil may result in higher pressure, the real goal would be to reduce heat, which would therefore bring viscosity back up a bit on the thinner oil.
Easier said than done, I’m sure, where an oil cooler would be required to reduce track temps, or in some cars where the oil cooler is already part of the coolant heat exchanger, reduced coolant temps from more efficient (or larger) radiators.
Maybe why my local 996 race shop only runs 0W40 in all street and tracked 996s.
My 968 track car, with dual oil coolers from RS Barn, almost never sees oil temps above 225F, even on the hottest days here in blistering central texas. I would imagine a turbo would get considerably hotter, but my oil coolers seem to be doing a great job of keeping my oil temp in check.
I've been using this oil for last 5 years on road and track, S2 and 951S. Read all the oil literature I could and then spoke to a Porsche race engineer who was also previously an oil tech for Castrol. He gave me a very long reply but in short said that the 10W 60 was a technically advanced oil (somewhat higher spec than the other Castrol synthetics). Very good protection at high temp with less propensity to breakdown and from his perspective equally important was excellent cold engine protection. He felt the cold start protection was better than the 20W 50 options (Castrol and others) and even those with high ZZDP which he says is great but not effective until engine warm.
I've read a lot but ultimately decided to follow the advice of someone who really seemed to know what he was talking about. He no longer worked for Castrol so there was no bias there.
High ZZDP is one of the first things I look for. If a fancy oil doesn't have it, I'm not buying it.
Castrol Edge 10W-60W has 1000bpm of ZZDP. ZDDP is a multifunctional additive; it has powerful antioxidant effect in addition to the antiwear characteristics. The size and type of the alkyl group attached to the Thio phosphate within the molecule influences the relative antiwear antioxidant balance of ZDDP additive. Over time Castrol have used modified ZDDPs that are more intended for wear performance and substituted other materials to boost antioxidant performance of our engine oils. So looking at Zinc and/or Phosphorus levels alone does not tell the full story in terms of wear protection. Also ZDDP is temperature activated so running the engine at low oil temperature also accelerates cam and tappet wear.
Castrol Edge Sport 10W-60 is recommended. Again this is formulated to 0.10% Phosphorus maximum and can be used with flat tappet followers with confidence.
Does that Castrol 10w-60 oil have enough detergents for our engines?
As it was specifically designed for dry or semi-dry sump applications, which generally don’t require as much detergent as a wet sump, my only concern is that there isn’t enough for wet sump street engines.
