New Aluminum Catch Can
#32
The part you are making bigger is a stock restriction inside the 3/8 opening in the top of the separator. You have to take off the separator and drill it out. Easy job if you are already in there...
#36
Originally posted by Tony
Take a line out of the bottom and route it to a point in the block above the oil level for a return.?? nice if you have the motor out.
[/B]
[/B]
First I'm going to drain it into a cup and see if I actually want that stuff to go back into my crankcase... But I imagine if it came out of the crankcase, there is already a bunch of the same type of junk already in the crankcase so it woulen't matter.
#37
Was I right that the conector to the oil tube does not change when you drill the seperator? So I can make my can with a 3/8 connector and use the same sized hose at both ends?
#38
i wouldn't drain it re-circ style... oil's cheap, engines aren't. if you have enough blow-by or what have you that you're draining this thing and adding significant amt's of oil every week, well, you've got bigger issues.
#39
NZ-
that is correct...
dmo-
Those were my thoughts as well, but since all the stuff that gets collected is in the crankcase to begin with, I would imagine it isn't a probelm to dump it back in... I guess I'll make up my mind when I look at what comes out.
Duke-
Did you want a can? I was going to make a shipment today (hopefully). I can send yours now if you'd like. Same thing for anyone else...
that is correct...
dmo-
Duke-
#41
I have the lindsey one, very VERY happy with every aspect - the hard-line they provided to run from the drain under the car (so you could set a can/jar/pan/whatever under there, then open the drain-****) broke -- but thats was because my dumb-*** smacked it pretty hard pulling the engine out last time (doh).
#42
Originally posted by Silverbullet951
Do any of you guys know how the lindsey unit is? Does anyone know someone that has one; I'm looking for some feedback.
Thanks.
Thanks.
that I get in the cabin with me now reburn thru the intake, I don't think the octane issue is a problem on the street, at the track add Xylene or race gas.
What I drain out now I would not want going back into the crankcase, water and oil mixture.
Just my 2 cents.
#44
Thanks Chris, I am out of town right now too.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
#45
Rennlist Junkie Forever
>>>If you are running an open catch can, it doesn't matter if it routes above or below the oil level.<<<
It should always be below the oil level.
TonyG
TonyG
