help...951 not running right
I got in my car to drive it and the idle was really rough. There was a lot of vibration. It acted like it wanted to die If I didn't give it gas. I turned it off and started it up again and it did the same thing. Any Ideas?
Thanks guys. I found the prob. The screw that goes into the top of the throttle body worked itself out. Luckily I found laying on the top of the engine.
That's the idle-speed adjuster. They tend to work themselves loose. Replace that O-ring on it before you re-install. Might also be a good idea to Locktite it in place and cover up the top with silicone.
