who is actually running without balance shafts?
SeaCay, I saw pics posted of a delete kit about 6 months ago and have never found who made them. Can you post or e-mail pics of the Scott Gomes kit? They don't have to be high quality, I just need something to eyeball.
Sam
Sam
Originally posted by TonyG
>>>So how do you get smooth as stock and certainly not in another? What are the differences between that would influence it?<<<
Good question.
TonyG
Good question.
TonyG
Nevermind I reread your 1st post.
My car is smooth, if anything the shifter might viberate just a little more but that is it and nothing has viberated loose in 10 k miles, so I don't know what the difference would be?
I've run with and without. For the street keep 'em. On a dedicated track or de car where evrything is checked reg. you can ditch 'em. As Tony said even with a lightened and bal. recip assbly. he still has some (vibration). These cars def. vibrate a lot more w/out them.
Balance shafts are there to cancel second order imbalance caused by the fact, that the pistons only perform a true harmonic motion, if the connecting rods are infinitely long. As a rule of thumb if a 4-cylinder engine is larger than 2 liters then they should have balance shafts, something I believe GM forgot (or cheapened out on) in their QUAD-4.
The disadvantage is obviously increased complexity and killing a few horses.
Laust
Laust
Thefu
Sam
Sam
Rennlist Junkie Forever
I'm not running a kit like that. I have no balance shafts, balance shaft covers, or any of the balance shaft gear.
My block was welded up when the short block was being built.
TonyG
TonyG
TonyG
TonyG
Not that I would want too
That's not bad at all actually, the machining time on those costs some money in this quantity. I wish Scott's web site didn't suck so much!
Sam
Sam
Yeah, my web site (or lack thereof) does suck for now, but I have a new site perpetually in the works...
Now, regarding balance shafts and their removal...
For starters, in a "completely" stock engine, the removal of the balance shafts is "almost" unnoticeable as there is still a lot of rotating mass which acts as a simple damper for small vibrations. That is not to say that the balance shafts do nothing, they do. The primary function of the balance shafts are to counter the secondary harmonics that are inherent in ALL inline four cylinder engines. The job of the balance shaft is relatively simple and it does its job quite well, BUT there is a misconception regarding the balance shafts function, read on...
Balance shafts do not eliminate the secondary harmonics (remember, they are inherent) - The balance shafts simply mask the "effect" of the harmonic which is a tempo vibration which will become more or less apparent at varying engine speeds, BUT keep in mind, they are internally present whether or not you run the balance shafts, only the subtle effect you feel becomes present when they are removed, and ONLY at certain "sustained" speeds.
So, why then do some people have silky smooth running engines, while others have bolts falling out? Well, you have to look at how much internal dampening has been removed from the engine. In a completely stock engine, the difference in feel with or without the shafts is based "mostly" on the factory internal balancing tolerances more than anything else. In a highly modified engine running a lightened crank, light rods, light pistons, lightened flywheel, and so on, the internal balancing becomes MUCH more critical as you are reducing the natural internal dampening of the additional mass. I have built MANY engines without balance shafts and can attest that "excessive" vibration (the type that will loosen bolts) is usually a result of parts that were not balanced together, and balanced to zero grams (or very close)
As a general rule, the lighter the internals, the more critical the balancing becomes.
Keep in mind that factory balancing allows the crank to be out as much as 12 grams!! Now, compound that with the rods, pistons, flywheel, clutch/pressure plate, belt pulleys, and so on, and you can be talking a lot of built-in imbalance right from the factory.
We eliminate the balance shafts in EVERY SINGLE race engine we build - Every one! We do it for several reasons; Lighter weight, less potential for leaks, and the simple fact that the factory balance shafts are virtually useless once you start changing the weight of all the internal and external rotating/reciprocating parts.
Are there circumstances where excessive vibrations are encountered when removing the shafts? Well, the simple answer is yes, BUT in these exceptional circumstances, the problem should not be isolated to the removal of the shafts, the problem lies elsewhere.
We have many folks that have been running our balance shaft delete kit for years (we have been making them since the mid 90's) and to the best of my knowledge none have had pieces fall off their cars from vibration, none have removed the kits to replace the shafts, and none have had any isolated catastrophic failures as a result of the shaft removal.
While we also weld up the blocks when possible, we developed this kit as a solution for those wanting to remove the shafts, but while keeping the engine in the vehicle. Also, they are 100% reversible should you decide to go back to running the balance shafts, which I am 99.94% sure you would not do once removed.
Thanks for those that have endorsed my kit and I appreciate the comments regarding the quality and such.
As stated earlier, the kits are $175.00 which includes everything you need to get the job done; Shaft bobbins/spacers, front covers, factory O-Rings for the covers and rear caps, all stainless hardware, and a bottle of Loctite 574.
Please feel free to ask if you have any questions, and I encourage any comments.
Thanks for reading, and I will do what I can to bring you all a better web site in the near future.
Thanks for your interest!
Hope this helps.
Hope this helps.
Scott, thanks for sharing the wisdom that comes from experience.
For whoever was asking the initial question: - I run without balance shafts in my yellow 951 (lots of lightened parts).
