Saratoga Tops
#47
Just an update as we go into April - the manufacturer is finishing up the production run and should start to deliver to the distributor soon. As of this morning, there is not a set ETA but things are progressing. I'm working with the distributor to figure out the easiest way to fulfill all these order requests - either with a group buy we me coordinating (and hopefully a lower price for everyone) or just to order direct from them like we initially had planned. I will continue to update as information is given to me.
#48
#52
I was contacted by PM by someone in the know that said there might be issues getting any of these tops fully produced. I'm thinking of finding alternative options. I'm in a holding pattern and am not sure what to tell you all as of today.
#54
Did anyone here get sent one of the update kits to secure them better? Can they post a picture so I could make one? I have a sunroof from the last batch by pilkington when there were all the issues with whistling, lifting, etc. I emailed about the update kit at the time and they were going to send them to the affected people when made - there were delays. I never got one so removed the top on the weekend, was getting pretty noisy over 120kmh, was worried it might lift.
Ps not a negative on these roofs, just an issue to be sorted
extempo (02-18-2023)
#59
Sam thank you very much. That is a huge help, doesn't look like it would be too hard to source something close locally oe even turn down urethane if necessary. Any measurements you get time for would be great, would make the top safe to use again.
