Airbag Control Unit
Copy paste,
PASSENGER SIDE AIRBAG & WARNING LIGHTS
At this point the car will run and the passenger side airbag will still be operational. However, the Airbag Indicator, Seat belt, and warning lights will remain lit because the SRS controller will register a fault from the disconnected driver's side airbag.
There are at least two methods that can be used to turn off the warning lights.
METHOD 1: SNIP THE WARNING LIGHT WIRES. The SRS controller is the bright orange module bolted to the underside of the dash in front of the glove box. It connects to the car harness through a round, 7-pin connector. The wire colors and functions are as follows:
1- brown, ground
2- red/black, central electric KL50
3- black/white, central electric N48
4- black /red, supply for DME relay
5- white, buzzer relay, seat belt
6- unused
7- yellow/black, airbag warning lamp
To keep the warning lights from activating, snip wires 5 and 7 on either the car side of the harness or at the controller itself. (Note: the wires directly attached to the controller are different colors). I didn't use this method because I didn't want to cut any wires in the car harness or controller. In any event, if you snip the wires or just leave the warning lights on, you do NOT KNOW THE STATUS OF THE SYSTEM. Therefore, I recommend the passenger side airbag also be removed or disconnected AT THE BAGS to ensure the bag contacts are shorted. This requires pulling the glove box, which is easily removed by taking out the 5 Phillips screws, the glove box light, and the glove box door. Removal of the passenger airbag is a PITA. I left mine intact, but disconnected.
METHOD 2: DISCONNECT THE CONTROLLER. This is the method I used. If you just disconnect the 7-pin connector the car won't start because the controller needs to send a signal to the DME relay via pin 4. This problem can be overcome by jumping pins 3 and 4 together so the relay receives a signal. The easiest method to do this is to use an old controller-side connector half from a bad controller... or the one from your old controller if you don't intend to use it again. This preserves the integrity of the stock wiring.
I suggest cutting all the wires off the back of the old plug except those corresponding to pins 3 and 4, solder or crimp those two wires together, and protect with shrink wrap or other suitable method (I sealed the back of the connector with RTV). Insert the modified plug into the car side connector half and the engine will start and function normally, and the warning lights will be deactivated :-)
I have one reservation about using this method however. In the event of a real crash that would have been sufficient to deploy the airbags, the controller interrupts power to the DME relay. This turns off the engine and fuel pump. By leaving the controller connected and snipping the warning light wires, this feature is retained.
Test the circuit. Probably a bad wire or cluster part. You might try bypassing the airbag light with the jumper method to see if it makes any changes. Take the cluster out and follow the trace lines and look for a break.
On mine, the PO disabled the air bag system. Part of that mod disabled the light. Do a search and you will find the mod. I reversed it on mine and now everything works. Although I've not tested the actual airbag deployment.
Thanks for the help all. What does PO mean? I have not modified my car at all if that is some type of mod. Glad no one has reported on deployment functionality. Intentional or otherwise!
YMMV
