Oil Thermostat - running without
Hi, i want to remove the stock oil thermostat, and run with an external mocal 70 degree thermostat.
Can i just remove the sleeve and thermostat and leave it? Or du i need to plug the oem filterhouse?
Erik
Erik
Rainman
the stock oil thermostat has a built in bypass passage.
some oil is always flowing through the cooler, even when cold. when the t-stat opens it just allows for full flow rather than a trickle.
if you wanted to run an external t-stat (why 70 degrees C, that seems very low for oil) you should be OK to remove the stock one entirely and just replace the cap on the housing.
