02 sensor....... help me find out which one I have please
Hey guys, 14 years ago my brother put in a round gauge to monitor A/F ratios on the pillar, problem is when the engine is running it is erratic with fast moving needle between very rich to very lean. From what I can gather the "eyeball" average seems to be about 14.7. I'm guessing its probably because its a narrow band system and NOT a wide band system. Do I have this correct? So, if I want to change over to a wide band, is it as simple as taking out that 02 sensor on the downpipe and exchanging for a wide band sensor? Is it the gauge that needs replacement, is it both? Will the wide band sensor have the same wiring to the ecu and be a direct replacement?
thanx for the info
Jaime
thanx for the info
Jaime
I have to correct something, the o2 sensor is actually in the stock location on the up-going pipe of the crossover pipe, so its likely a narrow band sensor as i've been told a wide band will not handle the high boost pressures. Also, since i have no sensor downwind from the turbo It must be a narrow band. The analog gauge itself does not say " wide band " like I've seen on google images. Do they even make an analog wide band? Looks like all of wide bands are digital.
I installed a wide band Bosch O2 sensor, actually had somebody else install it, but you can see it in the first picture above the wrench in the guy's hand:
Here is the wideband sensor that I installed. Don't have a part number.
Just google Bosch wideband and you'll find them all over, you have to make sure the connector on your gauge which also has a power supply lead, ground etc. hooks into it.
https://www.boschautoparts.com/en/au...oxygen-sensors
I have a digital gauge in my panel below the radio.
That looks like an Innovate LC-1 you have. I have the same wide band. I like mine.
Thanks for the pointers guys. Yes, same dme, o2 sensor is about 4 years old, car runs ok, but likely not optimal as it still has one of the original, first generation Lindsey Racing MAF (chrome cold side turbo body parts). Been researching VEMS vs Rogue vs Vitesse. I was hoping to see more activity and VEMS ownership. I really like what i read about the plug-n-play vems but not too many on the bandwagon for this. Anyone have any useful info on VEMS? You can pm me if you like.
thanx!
thanx!
