Wastegate
Wastegate
Is it possible to buy a Tial 35mm Wastegate off of ebay and just buy the adaptor kit if needed. The wastegates are going for around $120. Also i think i need a new wastegate becasue my boost starts to bleed off around 3500rpms. Also is it possible to rebuild the wastegate if you have the springs
Yes, it is possible but it is not economical (the adapters are high). Dont know about rebuilding the factory one (it can be done or no one would want the cores). Once you have screwed with removing it (top 5 biggest PITAs for me) you will want the best you can get.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Hi Cpt,
It consist of 2 steel plates about 1cm in thickness.
If you have excess to a milling machine & lathe
it's o.k. If not don't bother. It's gonna be a real
pain to diy the plates. If you get a machine shop
to do it for you, I don't think you're gonna save
much cause you're making only a set.
Drive-by provocation guy
GURU rebuilt stock wastegates, $190.00 14 psi in 1st, 15+ in all other gears to redline.
Gate does not start to open until 10-12 psi, for quick build up. Stock is 3-4 psi
ewainwright.
We have been working hard to put our web site on-line for the end of October, But we will have to wait for the end of january.
Our web site will be at www.europartsetc.com
I also sent you a P.M. concerning the wastegate price and all.
