Experience with Racepak Dashes?
Old 01-14-2018, 01:15 AM
Noahs944
Noahs944's Avatar
Again, bike technology, but this fellow explains a bit about motorbike "learning" tech:
Old 01-14-2018, 01:00 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I was able to calculate which gear the car was in based on the ratio of speedometer to tachometer pulses, as part of a now back-burner boost controller project. See demo video below. I had the benefit of knowing the gearing in advance, but you'd only need to run through the gears a few times for the processor to "learn" the gears. If you need help adapting any of the gauge sensors (fuel, etc.), I'm sure we could make an adapter box or two. I'm looking forward to seeing your "lean angle"
Old 01-15-2018, 04:41 AM
ealoken
ealoken's Avatar
I have some friends that has this in their racecars, and it always works flawless.
Old 01-15-2018, 07:38 AM
Noahs944
Noahs944's Avatar
Tom, Thanks for your video... it's inspiring!
I like the LED lights also. You are obviously a smart and skilled fella.
I will definitely keep you in mind as a resource if the gauge isn't compatible. Many thanks!!
Old 01-18-2018, 04:43 PM
Raceboy
Raceboy's Avatar
Gee, lol @ Motec 820USD for 250mb storage And then people recommend going Motec for a hot street car when someone asks which ECU to use. Usually in USA when people mean standalone most mean Motec (as in it is a synonym for standalone :P ).
Nowadays there are so many nice options for dashes like RealDash etc that work on Android and one can buy a 7" tablet and use that as a dash, everything is freely configurable etc.
Old 01-19-2018, 03:38 AM
ealoken
ealoken's Avatar
<- motec :P
Old 01-20-2018, 01:30 AM
Noahs944
Noahs944's Avatar
Hahaha.. that's funny. I wanna Motec exhaust too!
I got the order in a week. Fast shipping!
Just quickly tie wrapped to the wheel, will need to make a simple bracket.
Old 01-20-2018, 01:58 AM
rlm328
rlm328's Avatar
That is going to be a pain to read. A lot of the time you do not have a choice of when you glance at your dash. It will not always be on a straight...Warning lights always in a different place. But each to his own. Good luck
Old 01-20-2018, 10:30 AM
Noahs944
Noahs944's Avatar
I wont be attaching it to the steering column, hence why I need to make a bracket. The device needs to be with in reach of the driver because there are 2 buttons. I think it looks nice and is just about the perfect size.
Old 01-20-2018, 10:52 AM
Noahs944
Noahs944's Avatar
Darn, there are some neat products being designed nowadays!
https://www.demon-tweeks.co.uk/motor...control-system
Old 01-20-2018, 03:40 PM
Noahs944
Noahs944's Avatar
Hey does anyone know if this plug I tapped into is filtered oil? Thanks.
Quick Reply: Experience with Racepak Dashes?
