Cold Air intake project
Old 01-09-2018, 11:08 AM
gpr8er
gpr8er's Avatar
Default Cold Air intake project
Decided while waiting for my vems to arrive make a cold air intake. I didn't want to alter the headlights and found that I have plenty of room to go around and into the fender well
Old 01-09-2018, 11:10 AM
gpr8er
gpr8er's Avatar
Waiting for a another piece of material and then it's going to the welder
Old 01-09-2018, 11:20 AM
V2Rocket
Rainman
V2Rocket's Avatar
looks like a 3" pipe?
what filter are you going to run if tucked under the fender? i've looked at that a lot and don't think you could get a very big one down there.
Old 01-09-2018, 12:38 PM
MAGK944
MAGK944's Avatar
Puddle, gulp, hydrolock. Too low for my liking.
Old 01-09-2018, 12:39 PM
gpr8er
gpr8er's Avatar
TBD I believe I can fit the same size filter that I was running with the MAF
Old 01-09-2018, 12:44 PM
V2Rocket
Rainman
V2Rocket's Avatar
S. California, what's a puddle?
That said...how is this any more prone to sucking water than the stock airbox if you've got the plastic fender liner in place?
ecrouch01 (04-17-2022)
Old 01-09-2018, 01:40 PM
blade7
blade7's Avatar
Stick some 3" flexi tube on the end and you could mount the filter behind the bumper. What angles are those bends?
Old 01-09-2018, 02:33 PM
MAGK944
MAGK944's Avatar
1. Today: “A powerful storm system blowing through Southern California is producing heavy rain along with flash floods and life-threatening mudslide.”
2. A fender liner won’t stop water, if you mount your filter inside the fender liner it is somewhat lower than from where the stock air box draws air from.
Might not be an issue to you but it’s worth taking into account.
Old 01-09-2018, 03:27 PM
V2Rocket
Rainman
V2Rocket's Avatar
the fender liner is a splash shield to protect the air filter from puddles kicked up by the tires.
if the water on the ground is deep enough to come up to the air filter "hole in the fender" it'd be coming in the doorsills too...
Old 01-09-2018, 03:49 PM
MAGK944
MAGK944's Avatar
...if the water on the ground is deep enough to come up to the air filter "hole in the fender"...
ah ok, from the op’s picture it looked like the pipe was passing through the hole in the fender and adding an air filter to the end would make it considerably lower than the hole. So I’m guessing he’s cutting the pipe before the hole and adding a filter behind the headlight and level with the hole, my bad
Old 01-09-2018, 10:51 PM
gpr8er
gpr8er's Avatar
yes the filter is going in the behind the fender under the liner. It's going to be tight but I believe I can make it work. I shaved the back to the maker light and installed an LED bulb and sealed it up. BTW water is not going to be an issue for me. Looks like the pics were cropped for some reason after I uploaded them?
Old 01-10-2018, 01:47 AM
rlm328
rlm328's Avatar
My $0.02 worth. My cold air intake gets air just below the turn signals. I have raced when it rained so hard I had water inside the car, you could not see the track at all and I had zero water ingestation problems. See signature picture below, this is where the rain had let up a little.
One additional thought, once the car gets moving the air does not stay in one place long enough to get really warm.
Old 01-10-2018, 04:27 AM
DLS
DLS's Avatar
How big airfilter are you all using?
Old 01-10-2018, 07:49 AM
Thom
Thom's Avatar
Seconded.
I use a large-ish Injen cone filter (with inverted cone) with the Injen "Hydro-shield". It would not fit in the fender well, so located it below the horns. Never had a problem with water ingestion, whether after power-washing the car or driving in pouring rain. In fact I had more problem with a (smaller) cone filter located between the headlight and the coolant tank after power-washing the car.
In my opinion there is too little room in the fender well to make proper use of a properly large cone filter.
Old 01-29-2018, 06:46 AM
944crazy
944crazy's Avatar
Looks great so far, have you finished it? Any chance you would share the dimensions of it? I would like to get a direct copy made for my car.
Quick Reply: Cold Air intake project
