Tuning with the SMT6
#31
I definitely got the car dialed in today at 16 psi with a AFR of 12.3,,,glad I've got the 255 F1's on the back or it would have been a real hand full, specially in 2nd and 3rd gear! After starting out with a +4 fuel calibration setting my AFR's were around 10.9 -11.1, a little richer than I wanted. By simply reducing the fuel calibration by 2 I was able to get the AFR to 12.3 on my last group of runs. The thing thats nice about the SMT6 is that I can change fuel calibration settings which effects the amount of fuel throughout the entire range of the map or I can just change a specific cell/cells to change fuel for a given RPM range. Once the changes are made and down loaded form my lap top the results are instant. I keep the lap top in the passengers seat while I drive and tune as I go,,adding or deleting fuel depending on boost and WBO2 reading. Yeah, I know all this talk is cheap until I get to the dyno and post some results,,,,so, thats exactly what I plan to do this week!
#33
Jim, It's about time you turned up the boost
So you ended up using the map file I sent you, just added a 2 to the general calibration? How does the car feel? Where in the RPM range do you hit boost?
Email me your log file so I scan over it before your dyno session.
Keep in mind 15psi MAX on pump gas!!!
