16 year old porsche owner
hey guys new to here i'm puertorican livin in Augusta, Georgia just hopin to get some other porsche drivers to talk to and maybe contact some from georgia and get together and talk PORSCHE
gotta prob my rear hatch leaks problem is that the top of my glass like closes to the sunroof has come apart from the glass i've fixed this 3 times already i would take it off clean it real good take all the rubber and stuff off and sand the area where the galls is supose to stick to the frame then applied the silicone and placed the glass and put clamps but then i was lookin the other day through e-bay and i noticed something called a rear hatch seal as far as i know theres only silicone holdin the glass and frame together i didn't know there was a seal so if anybody has any tips to fix this prob and if anybody knows bout this rear hatch seal i'll appreciate it
The rear hatch goes eventually... usual fix is to dismantle it, straighten the aluminum frame and then glue it to the glass with some silicone.
There are several write-ups on the subject, see for example <a href="http://www.pelicanparts.com/techarticles/944_hatch_glass_repair/944_hatch_glass_repair2.htm" target="_blank">http://www.pelicanparts.com/techarticles/944_hatch_glass_repair/944_hatch_glass_repair2.htm</a>
Hope this helps!! <img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" />
The "rear hatch seal" is the seal that goes on the chassis, below the hatch. No seals are available for the hatch itself.
I'm afraid you must either continue plugging away at the leaks with silicone sealant, or change out the hatch completely with a used unit from a dismantler.
As for the cracked dash, I used a Coverlay "dash cap" on my 83 and am quite pleased with it.
anyone know of a goodsilicone to use that wont get messed up in the winter and like get loose again and also anyone know how to get flames out my exhaust
Going with the pack
is quite monotonous.
Go to this site and scroll down to rear hatch clinic. They have a kit with what you need to fix the rear hatch.
http://9xauto.com/944.html
You need a turbo to get the flames the right way.
