944 & 944S Forum 1982-1991
944 supercharging
Old 05-08-2010, 10:23 AM
rgs944
rgs944's Avatar
Default 944 supercharging
Does anyone know of how the 2.5L 944's have held up to supercharging. I know there are some out there. I like my 944 which I have had for 20 years so (I do not want to buy a Turbo). Another 75HP would be great. Heck if the price was right I would be tickled to death with another 40 or 50 HP if the price was reasonable, maybe somwhere around $3000. The kits that I have seen were more in the $6000 range. I also worry about putting to much HP into drivetrain that was not designed for it, so that is why I want to keep it modest and cheap. Any ideas.
Old 06-11-2010, 05:53 AM
dally_de
dally_de's Avatar
hi,
i have manage to make a setup for my n/a 944 ...plenty of power with 11 compression ration ..and at 0.7bar ...but the problem was that i could not set up the air-fuel mixture so took it off...probably a stand alone system would do the job but my budget for this ended. you can find allot of readings regarding to this modification .it can be done with allot less then 6000$
Old 06-11-2010, 07:16 PM
jbuck
jbuck's Avatar
Default Super Charging
http://www.speedforceracing.com/inde...productID=1028
Old 06-12-2010, 04:09 AM
Ghostcloak
Ghostcloak's Avatar
IIRC, N/A transmission has been rated for 250ft-lbs of torque. It's torque that kills transmissions/transaxles, not horsepower... I'm putting down 325 ft-lbs to the wheels and my n/a transaxle is holding up well. I've put 18k miles on it in the past 2 years, and I am playful (not abusive) with the car. 5th gear has a little bit of syncrho whining, possibly since that's one of the few gears where I've gone WOT a lot... But it all is still holding up longer than expected.
Make sure the fluid in the trans. is fresh, let the gearbox warm up before you play with it, avoid clutch dumping, and keep the drag racing to a minimum and you should be fine.
Old 07-14-2010, 11:21 PM
jason952
jason952's Avatar
just use an electric supercharger...
Old 07-21-2010, 05:28 AM
piperporsche180944
piperporsche180944's Avatar
Do you know how to make your 944 NA fast? Buy my 951 that has a mildly dinged up front end and fix it or swap everything into your 944 and make it a turbo sleeper. Just my $0.02
Old 07-24-2010, 07:42 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by dally_de
hi,
You could use the DIY tuning solution I released here:
DIY Tuning
Old 07-25-2010, 03:58 AM
Peenuttree
2nd Gear
Peenuttree's Avatar
Default electric superchargers!!!
What is this about electric superchargers, can someone tell me more about them?
Old 07-25-2010, 10:11 PM
Dryslick13
Dryslick13's Avatar
It is an electric fan that fits in the air intake. It has a switch that allows you to turn it off and on. Supposed to force air into the intake. They sell them on e-bay. Would be nice to hear if they actually work.
Old 07-25-2010, 11:58 PM
Eric_Oz_S2
Eric_Oz_S2's Avatar
Not tried them, but I know they don't work. You would need a very powerful electric motor to generate the required pressure, which would take a lot of room and require a very large power generation source (the alternator wouldn't come close).
Old 07-27-2010, 03:05 AM
Rogue_Ant
Rogue_Ant's Avatar
They don't. Don't waste your $$$.
Old 07-30-2010, 12:06 PM
FabilichuS
FabilichuS's Avatar
Well im hoping to get the SFR Stage 2 supercharger kit... Will hopefully have my engine compleatly rebuild in 2011 and probly get the supercharger at the end of 2011 or out in 2012... To bad it cost so mutch... But i will do anything for my little girl
Quick Reply: 944 supercharging
