Steering rack
Steering rack
Hey I’m replacing my steering rack and I can’t seem to get the steering wheel linkage to sit on the rack correctly so I can’t put the bolt through to hold it on. Was wondering if anyone had any suggestions
Are you saying that you can't get the intermediate shaft u joint to mate up with the notch in the pinion shaft so that the bolt can be inserted? If so, start by making sure you are aligning the right splines with each other. If it's not inserting all the way or is too tight I'll usually drive a cold chisel or fat screwdriver tip into the slot on the u joint to spread it a little.
If I remember correctly the notch is generous enough that you can be off one spline either way of center and still get the bolt through. Of course then your steering wheel will be off center but the good news there is that 944 steering wheels are not master splined, so you can just re index it back to center.
I’ve Ik most got it on but I think I am off a few splines cause my steering wheel is slightly crooked. The only thing is it won’t go on there enough to get the bolt through but I also can’t get it back off
