944 & 944S Forum 1982-1991
Side marker and tail lights not working
Old 12-17-2021, 12:27 PM
944Keith
Cruisin'
944Keith's Avatar
Default Side marker and tail lights not working
I’m about the pull my hair out (and I don’t have much left). I own a 1986 944 NA Auto that I’m bringing back from the dead. One issue that just started is my driver’s side tail lights and side markers have quit working. I’ve checked bulbs and fuses and nothing’s blown. I’m a novice at these repairs, but I’m learning. I’ve checked the tail light housing and there’s no corrosion. I have a feeling it’s a ground issue, but I have no idea on my next step. Has anyone had this problem before and how should I proceed to track this issue down?
Old 12-18-2021, 06:10 PM
Autobreza
Autobreza's Avatar
Had a similar issues, but affected some lights. I had been in the dash earlier and forgot to reconnect the emergency light switch. Worth a look if you've been in the dash recently.
Old 12-18-2021, 06:22 PM
TBarrow
TBarrow's Avatar
See if this helps find the ground areas...
Old 01-19-2022, 06:14 PM
944Keith
Cruisin'
944Keith's Avatar
It does help. Thank you. I’ve also been told to check the wiring under the fuse box to see if it’s a loose wire. I have cleaned and checked the MP IV ground, but that didn’t fix the problem.
Old 01-25-2022, 04:00 PM
djantlive
djantlive's Avatar
I had a similar issue where all the side markers and taillights were out. It happened after the bumper was taken off.
I ended up taking it to a shop. They pulled a new wire to the front side marker. Sometimes that’s what you have to do I guess
Old 01-25-2022, 11:00 PM
944Keith
Cruisin'
944Keith's Avatar
Here’s the latest twist to this puzzle. If I use the turn signal while the engine is off and the headlights off, the side lights come on. As soon as I turn the ignition and turn on the headlights, they go dark on the left side. Could this possibly have something to do with the headlight switch?
Old 01-26-2022, 08:59 AM
Tiger03447
Tiger03447's Avatar
Nope. try turning the steering wheel a bit to the right and left. Sounds like you might have a dirty turn signal switch or it's gone bad.
Old 01-26-2022, 12:50 PM
944Keith
Cruisin'
944Keith's Avatar
I’ll give it a shot. The turn signal switch is new. I had to replace it about a year ago and everything worked fine for a period of months. I don’t understand what can be causing the lights to go out when the ignition is on, but have them work when the ignition is off.
Old 02-03-2022, 04:52 PM
944Keith
Cruisin'
944Keith's Avatar
Doesn’t seem to be the turn signal switch. I’m leaning toward the headlight switch. May get one and try that out. Anyone got any other thoughts?
Old 09-28-2022, 03:41 PM
daz8161
7th Gear
daz8161's Avatar
I have this exact same issue. Did you ever find a solution to your problem?
Old 09-29-2022, 06:22 AM
Petza914
Petza914's Avatar
Received 6,264 Likes on 3,989 Posts
How about the turn signal relay? Also, you don't have led bulbs installed anywhere, do you?
Old 09-29-2022, 06:26 AM
daz8161
7th Gear
daz8161's Avatar
Ill have to check the relay but no leds fitted on the external lights, just a couple internally by previous owner but the lights were working fine when I bought the car from him.
Old 09-29-2022, 10:19 AM
orig944
orig944's Avatar
Headlight switch, specifically the contact in the headlight switch that sends power to the side that is not working. The parking light function is powered through the ignition switch, and appears to be working.
944Keith (10-02-2022)
Old 10-02-2022, 08:34 PM
944Keith
Cruisin'
944Keith's Avatar
I did. It was the headlight switch. When it was removed, it literally fell apart. When it was replaced, all the lights worked.
Old 10-08-2022, 03:34 PM
daz8161
7th Gear
daz8161's Avatar
Just to follow up mine was also a dodgey headlight switch. Replaced it and all working fine now.
Quick Reply: Side marker and tail lights not working
