Single use locknuts: A comprehensive list
Hi everyone. After sifting through the WSM and PET, I thought this list of single-use locknuts might be helpful to others as a time saver. 70 locknuts total: covering front suspension, steering, rear suspension, rear axles. I compiled the list by identifying each locknut in the WSM where in the right column it states "replace" or "renew". There were also a few that were not listed as "replace/renew", but I thought to add them to the list as well, being as though they have similar duties and composition. I then cross-referenced the PET ('86 version) for the part numbers. Please add any that may have been missed and also keep in mind this is for the mid-years and may not be representative of superseded part #s. I suspect the early or later cars may have differences but hopefully this'll get ya close.
900 910 031 09 : 26 total
2 - rear swaybar to linkage
4 - steering rack
12 - shock top to body (F & R)
4 - "chin-guard" to "frame"
4 - rear upper linkage (upper control arm)
900 380 010 09 : 4 total
4 - steering knuckle to ball joints (upper & lower)
900 910 094 02 : 10 total
4 - front upper wishbone to body
4 - rear lower control arm to shock bottom
2 - rear lower control arm to crossmember eccentric
900 910 046 02 : 10 total
2 - shock lower to lower control arm bracket
2 - tierods
2 - engine crossmember diagonals
4 - engine mounts
N 022 141 4 : 6 total
4 - ball joints to lower control arm bracket
2 - rear lower control arm front eccentric
N 022 141 1 : 2 total
2 - front swaybar to linkage
900 910 093 02 : 2 total
2 - rear axleshaft to hub
900 910 022 02 : 6 total
2 - steering shaft u-joint
4 - lower (under rack) steering plate
900 910 010 09 : 4 total
4 - handbrake cable to rear crossmember
4 - steering rack
2 - tierods
4 - engine mounts
Great compilation. I was going to check WSM before putting my suspension back together, but entirely possible I would have missed this detail and died in a firey wreck.
That's a great effort, Ladybug83 - thanks. On my next 928 purchase, I'll ask if all fasteners were properly renewed! That will be worth a few bucks on the negotiation. I hope I'm not asked about them when I sell. Are their many cases of re-used nuts and bolts backing off?
