928 Forum 1978-1995
Sponsored by: 928 Specialists
Waking up a 17 year dormant 1984 928S
Old 07-13-2017, 02:55 PM
  #196
Socal_Tom
Socal_Tom's Avatar
Well that explains the shift issues
Old 07-13-2017, 05:32 PM
  #197
Socal_Tom
Socal_Tom's Avatar
I am soaking the grub screw in penetrating fluid now. Iis there anything else I should be aware of when trying to remove it beyond that in making sure the Allen key is fully inserted ? Carefully put some heat on it via blue torch maybe?
Old 07-13-2017, 08:24 PM
  #198
Socal_Tom
Socal_Tom's Avatar
Success - thanks guys
Old 07-13-2017, 08:55 PM
  #199
AirtekHVAC
AirtekHVAC's Avatar
Alright! Keep it up!
Old 07-13-2017, 09:46 PM
  #200
Socal_Tom
Socal_Tom's Avatar
Hmmmm - the coupler is still stuck on. How much force should it take to remove?
Old 07-13-2017, 10:01 PM
  #201
Socal_Tom
Socal_Tom's Avatar
Trying more heat and a whack load of penetrating fluid. (Whack load being a highly precise amount of course)
Old 07-25-2017, 01:37 PM
  #202
Socal_Tom
Socal_Tom's Avatar
Still not budging, hit it with more heat yesterday and more PBlaster. Used a mirror to confirm that nothing is holding it in place. Ugh.
Old 07-26-2017, 08:08 PM
  #203
Socal_Tom
Socal_Tom's Avatar
Decided to leave the couplerer for another day and made some progress on the cooling system. New thermostat, seal, and a nice and clean neck back installed.
Old 07-26-2017, 08:50 PM
  #204
AirtekHVAC
AirtekHVAC's Avatar
Looking good sir....seems like my rear coupler just pulled right off, if I recall....
Old 07-26-2017, 09:06 PM
  #205
Socal_Tom
Socal_Tom's Avatar
Hi there-hope you are having a good week. I don't know what sort of super duper adhesive was used but something is holding that rear coupler on there totally tight.
Open for ideas on getting it off!
Old 07-27-2017, 01:40 PM
  #206
Socal_Tom
Socal_Tom's Avatar
Got some good news this morning-both of my ECUs, the original one to the car and the one I picked up from that sad 928 being parted out near San Diego, appeared to be healthy.
Quick thank you to Olie at Welding Works for his help testing the ECUs.
Do I get any bonus points for today's longest run on sentence ?
Old 07-27-2017, 02:16 PM
  #207
skpyle
skpyle's Avatar
Nope.
Some of us illiterates here do that all the time.
You need to step up to 'run on paragraph' to be considered.
Old 07-27-2017, 03:24 PM
  #208
Socal_Tom
Socal_Tom's Avatar
Originally Posted by skpyle
Nope.
I will take that as a challenge!
Hope you're having a good day.
Old 07-27-2017, 06:23 PM
  #209
Socal_Tom
Socal_Tom's Avatar
Installed both new coolant hoses - by far the easiest thing on the entire to do so far.
Any yes, I am procrastinating on the rear coupler issue.
Old 08-20-2017, 06:50 PM
  #210
Socal_Tom
Socal_Tom's Avatar
Installed the new injectors and reconnected the fuel rails.
Need to suck it up and get the old FI harness out of there and the new-old on installed this week.
Quick Reply: Waking up a 17 year dormant 1984 928S
