FS: Ritech Clamp-SOLD
#47
Basic Site Sponsor
Basic Site Sponsor
When these cars were created, the torque tube shafts needed to be made from a steel that would flex and return to its original position. The steel they used was soft enough that the splines wouldn't survive unless there was no movement between the splines on the shaft and the splines in the coupler. Therefore, they clamped the splines on the automatics. On the manuals, they needed the splines to move (clutch discs), so they made a harder "short shaft" and coupled that to the softer torque tube.
Two different materials required back then.
People that are following closely will realize that I'm using 300M for both my manual transmission short shafts and my torque tube shafts....
One material for both functions!
I'm making automatic flex plate couplers that are as hard as the center in the clutch discs....eliminating any and all need for clamping. My new automatic coupler and existing torque tube shafts (for the automatics) will "float"....just like clutch discs do!
Problem solved! Throw away all the clamps and apply clutch disc spline lubrication.
No more engine damage remotely possible!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#48
Administrator - "Tyson"
Todd and I discussed many times doing exactly what you are doing. Ultimately he's not in a position to do all the R&D for such a product (like you have been) since he already had his DOM tube driveshaft in development.
Nice work! Any "rough" ETA we can plan around? I need to eventually pull my trans to re-seal it and would be nice to plan around such an upgrade.
#49
Basic Site Sponsor
Basic Site Sponsor
That is the first thing Todd did when he made his twin turbo, just left the coupler loose so it could float. He was willing to sacrifice the shaft splines since he didn't want to risk the engine from a thrust bearing issue.
Todd and I discussed many times doing exactly what you are doing. Untimely he's not in a position to do all the R&D for such a product (like you have been) since he already had his DOM tube driveshaft in development.
#50
Perfect, since I plan to pull the trans this winter!
#52
Good question.....and brings up the chance for me to promote a new product I'm working on.
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!
GimmegimmegimmegimmegimmegimmeGIMME!!!
#54
Why does the drive shaft have the small neck turned on it right at the end of the splines, between the splines and the rest of the shaft?
#55
BTDT when we did our initial research into TBF many years ago and we finally defaulted to a much better clamp, the Super Clamp.
This wont be as easy as you think.
Cheers,
Constantine
Cheers,
Constantine
#56
Now that is simply fantastic.
#57
So, Greg, if you are making the shafts out of better material that wont need a clamp. why are you still making a short shaft for the manuals rather than just one shaft like with the automatics?
#58
#59
#60
Basic Site Sponsor
Basic Site Sponsor
The machine that cuts the splines needs room to run past the splines. That area needs to be undercut. The stock shafts have the same feature.
