928 Forum 1978-1995
Sponsored by: 928 Specialists
Air Filter Selection
Old 04-25-2017, 10:06 PM
PaulCarrera
PaulCarrera's Avatar
Default Air Filter Selection
84 928 S2 euro
Just about to change my air filter and I can get a normal one or I can go for a K & N one that is supposed to be better air flow but also cleanable for twice the price so wondering if they are really any better and if you can really clean and reuse them. Anybody with any experience of using them?
Also I have come across the pipercross washable foam ones that sound good for a little less than the K & N with lifetime warranty
Old 04-25-2017, 10:08 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,182 Likes on 1,232 Posts
Stock, easy to find and they work.
After you've taken out a number of K&N filters only to find debris on the MAF screen, you realize they let more dirt through.
I won't even go into the controversy of the K&N oil killing the MAF hot wire.
Old 04-25-2017, 10:20 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Unless youre over 700Hp, stock filter works fine, and filters 10x better than a K&N dirtflow.
Old 04-25-2017, 10:29 PM
PaulCarrera
thanks guys I will stick to stock then
Old 04-26-2017, 01:04 AM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
...just make sure you don't install the original spec filter upside down, ...it's as bad as not knowing you are missing the jump post cover.
Old 04-26-2017, 01:41 AM
The Forgotten On
The Forgotten On's Avatar
^^ for most others, it causes it to run lean.
Old 04-26-2017, 02:06 AM
Speedtoys
Speedtoys's Avatar
Which makes no sense.
Its not a carb/jetted engine.
Old 04-26-2017, 02:54 AM
OTR18WHEELER
I don't think the k&n causes a lean condition, it will allow more air through though.,....wait a minute, that would cause a lean mixture.
Old 04-26-2017, 08:50 AM
hacker-pschorr
The paltry amount of additional air possibly allowed through by a K&N filter is well within the operating range of the air meter from any year 928. If these cars had that narrow of an operating range, you couldn't drive from death valley to Pikes Peak without re-tuning the engine.
Old 04-26-2017, 09:31 AM
The Forgotten On
It's the hump of the air filter that prevents air flow if flipped the wrong direction
Old 04-26-2017, 11:19 AM
jcorenman
jcorenman's Avatar
The MAF meters airflow, whatever it is, so a restrictive filter or high altitude won't change the air/fuel mixture: less air means less fuel.
Where things do get messed up is that the MAF only measures airflow in the little venturi gizmo, in the central 1" or so of the MAF housing. If the flow is uniform across the whole MAF then this central measurement is an accurate estimate of the total airflow. And uniform airflow requires some plenum volume upstream of the MAF, so that the air has a chance to settle down and flow smoothly.
Which is Blake's point, and is exactly right-- the hump in the filter does reduce the "headroom" above the MAF intake, which does restrict the airflow to a degree. But it also messes up the distribution of that air flowing through the MAF. If the flow is now weaker in the center then the MAF will under-estimate airflow and reduce fuel to match, which results a weak mixture.
Bottom line: Do it like the factory did it, stock filter and right-side up... Or change it completely (velocity stacks through the hood?) and re-tune.
Old 04-26-2017, 11:41 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,448 Likes on 1,374 Posts
I have a brand new KnN filter that came on my 80 Euro 5 speed,
I was going to give it away.
Doh thats not nice ,
I will just stick it in the trash
lots of little stones under the new filter, musta leaked around the edges
Old 04-26-2017, 02:33 PM
corellian vette
corellian vette's Avatar
OK now you have me questioning - which IS the proper way to mount the air filter? There were no markings on the one I got - and the look like they fit either way.
In my case, the Flat part is facing DOWN (towards MAF) and the HUMP is facing up. Did I get it right?
Old 04-26-2017, 02:35 PM
skpyle
skpyle's Avatar
Stan, that's what I did with mine...
Old 04-26-2017, 02:42 PM
Speedtoys
Speedtoys's Avatar
Yup!
Quick Reply: Air Filter Selection
