928 Forum 1978-1995
Sponsored by: 928 Specialists
Sill cover parts no. help
Old 07-23-2017, 07:26 AM
Marti
Marti's Avatar
Originally Posted by Marti
Does anyone have any spare of these washers? They would have to come from a car being parted out or new old stock?
Seems the answer to this is no
Old 07-23-2017, 07:30 AM
Marti
Marti's Avatar
Originally Posted by ROG100
Try ----
999 591 717 40 Expander Nut
N 011 665 3 Washer 5.3
900 143 085 07 Tapping Screw 4.5 x 16
These parts are for the underside of the sill cover not the top. These are available but I have confirmed with the Porsche factory that the special washers for the top side of the sill are NLA unfortunately
3D printing is an option when the price comes down to a more commercially acceptable price.
Old 07-23-2017, 08:17 AM
Marti
Marti's Avatar
Try ----
Old 07-23-2017, 08:23 AM
Marti
Marti's Avatar
The best alternative I could find are aircraft washer as pictured below. They don't unfortunately feature the dead stop ability of the original version but are a good fit otherwise.
The size is 0.6 of an inch. The original screws sit almost flush if you drill the hole out to 5mm .
This is far closer than anything else I could find . Hope you find this useful and happy 928ing
Old 07-23-2017, 10:06 AM
Jerry Feather
Jerry Feather's Avatar
Turning a handfull of them out of some plastic stock in a lathe should have been a fairly simple solution. Kind of old fashioned - - I know.
Old 07-23-2017, 06:03 PM
Marti
Marti's Avatar
I wish it was that simple Jerry, it seems nobody can do anything without CAD files these days.
The aircraft washers were less than £10 so were also cost effective.
If you know someone that could produce these things then I am sure there will be a demand as the original brass fittings simply fall apart when you try to remove them. I am also told 911 use similar parts so who ever can knock these out could find a market for them, he'll I would take a set.
Old 07-24-2017, 02:45 PM
ROG100
Basic Sponsor
ROG100's Avatar
After nearly 15 years in the 928 parts business you are the first customer to ask the question I doubt the market is huge but if someone makes them that would be great.
Old 07-24-2017, 05:57 PM
Marti
Marti's Avatar
Hi Roger
I think the parts have now reached an age where the metal has become brittle so I would expect anyone repainting sill covers or even some needing to remove and refit sill covers on S4/GT/GTS to have the issue of these breaking - unless you are lucky and have somehow avoided the aging process?
Whether people want to make do with raised screw heads or not refitting the black plastic cover which goes over the screws I don't know. I definitely wanted to replicate the factory finish in this area as opposed to the other options I mentioned. What I found gets very close and will allow me to retain the factory finish just without the dead stop attribute.
Old 01-12-2020, 01:38 PM
Smitje 928
Smitje 928's Avatar
Hi Marti,
I'm trying to revive your thread as I am facing the same issue on my car.
I took the door sill cover off and some of the washers you describe were broken and so brittle that I couldn't use them anymore.
Also, there are plastic oval grommets on the bottom of the sill cover that fall out and that I haven't been able to find in PET. Check the right picture below:
Has anyone found a solution for the top washers other than yours Marti? If not, then:
1. can you provide me with the details of where you got them?
2. Would a plastic washer do the trick? Aka would it be an idea to have a plastic version 3D printed?
As for the one on the bottom: I will try to get a specialist use a decent old one and get some 3D printed. No idea if it will work but it can't be rocket science……
Cheers,
Manfred
Old 01-12-2020, 02:27 PM
ROG100
Basic Sponsor
ROG100's Avatar
Long shot but take a look at the 968 Pet illustration 810-005 - similar cladding to the 928. Shows an oval shaped washer 928 559 313 02.
Also grommets 999 702 160 40 & 999 702 202 50
Old 01-12-2020, 05:05 PM
Smitje 928
Smitje 928's Avatar
Again, you are the best Roger...!!!!!
Those washers definitely look like the correct ones! What sort of strikes me is that they have a "928....." parts number but don't show up in the relevant 928 PET.....
I'll order some and check if they match the ones that came of my sill cover.
Unfortunately the grommets from the 968 PET are not the grommets that go in to the top of the sill cover. Hopefully Marti can provide his source, otherwise I hope an alternative shows up somewhere.....
Thanks again, Roger...!!!!!!
Manfred
Old 01-12-2020, 05:45 PM
Tony
Tony's Avatar
So to remove that , its a matter of those screws and releasing the adhesive tape?
Old 01-12-2020, 06:24 PM
Smitje 928
Smitje 928's Avatar
Hi Tony,
Basically yes, although PET shows a screw at the back inside the wheel well (810-05 nr 21) but if I read PET correctly it only applies to the very early S4 cars (up to VIN 40080 for the Euro cars; my VIN ends with 40715 and my car doesn't have that screw).
Be careful with those screws on the top of the sill cover: they tend to be stuck and I had to drill one out (check the photo in the middle):
The Arrow on the left photo above is showing the remains of the cover strip which didn't survive the operation…..
Sorry for the combination-photo: I took it out of the write up I made on removing my side trim.
Manfred
Old 01-13-2020, 12:39 PM
ROG100
Basic Sponsor
ROG100's Avatar
Pictures of 928 559 313 02 - metal not rubber/plastic
Old 01-13-2020, 12:47 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
I can't imagine how anyone would get the 25+ year old plastic upper trim strip (928 559 289/290 05) out of the channel in the sill without tearing it. I treat them as (expensive) disposables.
Here's a shot of all the sill hardware from one side of an '89:
Quick Reply: Sill cover parts no. help
