928 Forum 1978-1995
Sponsored by: 928 Specialists
Saving a '79 Euro
Old Jun 2, 2017 | 10:03 AM
  #76
docmirror's Avatar
docmirror
Shameful Thread Killer
Don't forget the air channels. Radiators are a water/air heat exchange method. If you have the rad out, blow compressed air from the back side, to the front and you'll be amazed how much of those little pebbles will come out. You can also use pressurized water from the back to the front, but be careful about the amount of pressure used. I have a pressure washer that is adjustable, and I set it down to a lower pressure point, and keep the nozzle back far enough so I don't bend the fins. You can flush out a lot of crud from the air channels with patience.
Old Jun 2, 2017 | 08:17 PM
  #77
kiwiokie's Avatar
kiwiokie
Will do that too! Thanks!
Old Jun 2, 2017 | 11:29 PM
  #78
VanD's Avatar
VanD
Originally Posted by kiwiokie
Got my COA. VanD was right about cloth inserts but pinstripe rather than pasha. Leatherette but sure looks and feels like leather to me!
But I was wrong about it being Copper Metallic - Congrats on a Tabac car - it's a great color!
Old Jun 2, 2017 | 11:52 PM
  #79
77tony's Avatar
77tony
Veteran: Army
Agree with Alex^^^and color of my first 928...an 80 Euro S. Look forward to your progress T
File Type: jpg
Old Jun 4, 2017 | 09:32 AM
  #80
kiwiokie's Avatar
kiwiokie
Thanks Alex. I love this color. Right up there with petrol blue and light green IMO. From what I have read the cork pinstripe material is NLA so will have to do something different for the interior. Maybe the brown pinstripe or brown/cream pasha. Plenty of time to decide since I am not even close to putting the engine back together (water bridge woes), then there is the clutch to address, then brake pads and hoses, and the '86 dual exhaust that I bought.....
Old Jun 4, 2017 | 11:38 AM
  #81
Jadz928's Avatar
Jadz928
^^^ gorgeous color!
No worries about the water bridge woes and to-do's. They seem infinite with the 928 but they're not. Enjoy the process when you can and pick them off one-by-one.
Also, the '86 dual each as nice as it may be is too much for the 4.5L
Consider sourcing a single pipe system.
Old Jun 4, 2017 | 12:52 PM
  #82
kiwiokie's Avatar
kiwiokie
^ too late Jim. Already have the manifolds and the rest is on a Greyhound somewhere between Oklahoma and Arizona. Wanted to replace the ANSA with the proper pumpkin and tip. Somewhere along the way my car picked up a dual cat Y pipe that could probably anchor a cruise liner so wanted to shed some weight also. Will there not be enough back pressure with the dual pipes?
Old Jun 4, 2017 | 01:47 PM
  #83
Jadz928's Avatar
Jadz928
Re backpressure, possibly yes. Certainly it's more pipe diameter.
It was designed for the 300hp 4.7L. But was it also used for the lower HP 4.7 in the same config later on?
The difference may be negligible. Maybe someone more knowledgeable will chime in on this.
Old Jun 4, 2017 | 03:24 PM
  #84
kiwiokie's Avatar
kiwiokie
Well I will give it a try. Might be a good excuse to upgrade to a 4.7l Euro S engine in the future ;-)
