Saving a '79 Euro
#61
Thanks Hoi!!!! I will give that a try.
For the rubber bushings that had sheared off underneath the air plenum, I had used a chisel and a hammer to slowly "rotate" the bushings counterclockwise to loosen them up then a pair of tooth pliers to "unscrew" them. I think I read it somewhere here that Greg Brown has used this method and it worked for me. Good luck.
-Hoi
-Hoi
#62
Thanks Alex. Went to Home Depot and bought a 5ft 3/4inch galvanized pipe and tried that out on the breaker bar - hung on it until I thought the breaker bar would bend but the bolt did not move. I will try more Kroil each day this week and maybe will get lucky in a few days.
EDIT: forget the above, I remembered my favorite trick. Place your breaker bar handle onto a jack and pump up until the bolt loosens. This has never failed me yet and takes hardly any effort.
#63
Finally got the crank pulley bolt out. Ended up cutting some aluminum flashing to the size of the fan belt pulley and duct taped it to the pulley forming a cup. I mixed 50:50 ATF and acetone and filled the pulley up which submerged the bolt. Fortunately the duct tape held for a day which was long enough for it to have an effect. Was still freaking tight to remove!
#66
Looking almost clean! AC compressor still a pit of primeval slime. Need to discharge system first. Previous owner said AC never worked so was hoping it had no freon but no such luck.
#67
Can anyone help ID what goes here? This is underneath the crank end. Whatever was there is long gone. Guide rail perhaps? Hard to tell from the PET diagram.
#70
Had a day of incredible wrenching karma last week and got all waterpump bolts out without any fuss at all. Could not have been more surprised. Waterbridge Allen socket bolts are another story. Lots of flakey scaling inside the waterpump.
#72
Agreed. When I drained the block and radiator it looked to be 98% water and likely tap water rather than distilled. I need to look for one of those flush products to cycle through once I get the engine all back together.
#74
Shameful Thread Killer
Glad you got the COA and it's mostly what you want. Gonna be a great example when you're done. Keep on keepin on.
