engine removal need help
Next week i will take out the engine from my car , i bought an engine rack (1500lbs capacity) with steel wheels and the turning bracket to turn the engine on itself.
What i need to know is from where am i gonna fix the bracket to the engine ?
from the ring gear ? or after removal of the ring gear or is the coupling of the torque tube strong enough for that ?
Thank's a lot Glen You're the best !!!!
By the way would you give me an advice to clean my more than dirty engine ? it's not oily it's greasy , i don't know what the p.o. did with that car but i've never seen a dirty engine like that, i tried a little bit of engine shampoo but it does'nt look like working. Thank you
Commercial degreaser, like toofast928 describes, works well. As the block is aluminum, washing it down with water is not a problem at all.
Sometimes I'll make some home-brew stuff with 2 parts paint thinner, one part laundry detergent and one part water. Rinse that with water.
After things are cleaned, the first time, I'll dry them and then use straight paint thinner or, often, lacquer thinner. Just wiping it with a dampened rag gets that last bit of oil off.
What I do, is use plain old engine degreaser but wash it off w/a pressure washer.
As far as I know, store bought aerosol engine degreaser has no ill effects on aluminum but the fumes are brutal. Not - user friendly.
If you know someone who has a heated P/W, even better.
A former friend had a 220 BTU PW and it cut through grease and oil like nothing else.
Thank's a lot guys , with all your advices i'll be more comfident for the next step !
After it wil be the timing belt battle !
One thing is sure ,it's that without the existence of the forum and you guys i would'nt have gone trough that crazy project of restoring the car of my dreams, i hope it won't become a nightmare !
Thank's a.m..
Thank's a.m..
