Intake refresh and now wont run...
Intake refresh and now wont run...FIXED!!!! New Video for comments added.
Need to see if anyone has any ideas...here is what has been done:
New plugs, wires, rotor and distributor
New fuel lines
Injectors have been cleaned and rebuilt
New vacuum lines
New Brake Master
New water bridge seals
New thermostat and seal
So it sounds like an air/fuel issue to me (not electrical/spark - or else it would not run).
I know the idle speed screw is misadjusted - not sure where to start with that.
In the video, first attempt is no pedal at all. Second attempt I am flooring the gas pedal for most of the running and as I slowly let off the engine dies...Thoughts?
Thanks all -
scott
New fuel lines
New vacuum lines
New Brake Master
Thanks all -
scott
Last edited by drscottsmith; 01-17-2017 at 09:25 AM. Reason: FIXED!!! Updates added.
Continued
fussing at my son and hit the button. I was assuming none of that would have changed as I only disconnected and reconnected the lines.
But I will get a gauge and check.
If it's not hitting on all 8 you should be able to hit the exhaust manifolds with a laser thermometer and see which ones are cold. Not easy to do from under the car, but...
Good luck brother. I know it's frustrating.
Grounds et al
Thanks all!
i cleaned the CE panel and all the grounds before taking the intake apart...would not think that would be it.
I have checked ignition leads (several times)...but will recheck. I agree with Seth and Chris though - we are not firing on all 8 right now.
I am am going after a noid to check signal on injectors and then need to check the exhaust temps. Hoping I did not mess up the fuel injectors when I rebuilt them.
will keep everyone updated!
-scott
-scott
Did you rebuild the injectors? If you didn't when were they done and how long before you installed them?
Very quickly they will oxidize inside within a week after being cleaned
You are close! I bet the problem is some simple stupid thing. Did you finger-tighten any ground bolts and forget to follow up?
If that was a cold start the idle RPM sounds way too low.
Hmmmm.....
Team Owner
what exactly did you do to the injectors to rebuild them?
