Sunroof interior trim panel 3 screws..
Two of the three are stripped, use the next size screw?
Whats the next best option?
Archive Gatekeeper
Well now that we know to look for them, yeah.
Maybe you could find a screw with the same head but machine threads and then drill the hole out and put in a flush rivnut with the same threads.
Its not that bad, with the roof half open..slide in the panel, and work the tabs behind the screws (dont remove them when you pull the panel), and then open it all the way, put your head in the sunroof opening, and you can see em just fine.
I used good lighting from portable COB LED inspection lamp, and magnetised screwdriver to hold screws before starting them in tabs. It was fiddly but not frustrating. Good light is key.
