Hella H4 - questions
All -
Are the Hella H4 lamps "universal"? So if I find an 8" unit for another car will it fit the 928?
If not universal is there any way of knowing a cross reference of what would work?
Thanks -
- scott
Thanks -
- scott
Electron Wrangler
In 8" - unless you want to do a lot of fabricating - the only thing that will fit easily is the custom designed 928 version from Bosch (LHD & RHD versions & DOT LHD in USA) - I've never heard of folks doing/documenting any other 8" conversions nor have I heard of Hella 8" lenses installed on a 928 (in stock locations).
In 7" sizes (with trim rings) you can much more easily adapt other lenses to fit - if you already have the carrier - e.g. for sealed beam (crappy) DOT lens/reflectors. You can certainly use 7" lamps (lens / reflector / bulb holder) from Bosch, Hella, Cibie & Marchal - likely many others too - but these are the obvious premium brands.
Alan
Alan
Thanks Alan - sounds good! And thank you for all of your other posts and the electrical handbook you have posted. Been very helpful so far!!
-scott
-scott
I use 8" H4's with 55/100 bulbs which will light up the world on high beam.
The H5's are crap, H4's are available new but the are not cheap. I think they average around $350 each. Plenty of used ones around, i even think Mark Anderson has a few.
You can also use the 7in H4's with the brighter bulbs. As I understand it the earlier 8" H4's did not have the bump or the indicator on the top.
Electron Wrangler
Alan
The Parts Whisperer
