Rebuilt Water Pumps
#107
Shameful Thread Killer
I have little to offer, but here goes.
The theory of the design of the 928 belt path and tensioner is that a seized WP will not cause a catastrophic failure if the belt path is in nominal condition, and the driver stops when the belt tension light(where applicable) comes on.
In real life practice, on my 88 I changed my belt, left pulley, tensioner bearing, and refurbished the tension asm but did NOT change the WP, as it was functional, and I was askeered to put something else in. After ~1300 miles(tension checked @1000 mi as req), I suffered a seized WP with bearing failure and shaft canted up ~15deg, loss of tension light, and I stopped the car immediately without catastrophic engine damage.
This is one case, and the only conclusion I can draw is that it all worked as Porsche designed. YMMV.
#108
Received 1,682 Likes
As for the rest, some folks on this forum (not naming names, don't even remember 'em) stand-by the notion that a 'used' water pump will always fail after you tighten up a new belt. I'm not sure I buy it. Not satisfied with explanations of the physics. Maybe if the 'old' belt was too loose all the time. But, if the 'old' belt was properly tensioned why would the same tension with a new belt put any different stress on the WP? Because it's new. Magic.
Or maybe if the WP was a zillion miles old. Then it was gonna bust anyway. New belt or old.
#109
Here's an interesting one from an early 93 GTS with 47k on it. Owner had it changed not so long ago in 2013 and wanted to be able to tell any new buyer that it was done this year by me. The pump has an '86 stamping but I've not seen this impeller before. Anyone seen one like this before?
#110
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Is this an Autopac rebuild? The first pump replaced on my 928 had a pump with a metal impeller. It's look was very similar to this, but a receipt showed it to be an Autopac rebuild. I don't remember if there was an "R" on the casting after the 928 part number.
#111
Nope, this isn't an autopac one. Don't have a clue where it came from and the owners invoice shows no identification.
#113
The step around the shaft is a new one on me. Never seen an impeller like that before. Not Lasa, Autopac or Porsche. No-name rebuild? What was the part price on the previous invoice?
#114
Trying to find that stuff out, customer is out of town starting today and won't be back until Friday.
#116
Fuse 24 Assassin
Fuse 24 Assassin
The center bushing reminds me of what Laso did with their plastic impeller on the redesign. Perhaps this bushing even stopped the walking of a metal impeller as well?
#118
Fuse 24 Assassin
Fuse 24 Assassin
I'm putting this link here.
http://www.sonnenporscheoemparts.com...ame=water-pump
Supposedly this is a Genuine Porsche water pump (rebuild???) from the dealer just down the road from me. Fairly inexpensive, and makes me believe it really is a rebuilt pump from Porsche.
#119
Today's Laso. You can see the difference in the impellers.
None of the old pumps I have here look anything like this one I posted today. Hence the questions.
#120
Andy, call them and ask Neil who rebuilds the pumps. Porsche doesn't but lets see what his answer is.
