928 Forum 1978-1995
Sponsored by: 928 Specialists
944 Heads?
Old Oct 20, 2003 | 01:36 PM
Mark's Avatar
Mark
Default 944 Heads?
Anybody BTDT?
Considering putting 944 Heads on an 85 EURO motor...
Considerations? PICS?? Dyno results? Any comments?
Old Oct 20, 2003 | 04:09 PM
Jim @ EuroWerks's Avatar
Jim @ EuroWerks
A few years ago excellence fetured an early 928 bored and stroked to 350ci . they used 944 heads, said they flowed better.
Old Oct 21, 2003 | 01:52 AM
2V4V's Avatar
2V4V
Mark,
You can put 944 heads ona 928.
BUT....
The first concern is valve clearance. If you are using a 2v euro motor it should not prove an issue though I have never done a "dry fit" of that exact assembly so I would not be 100% sure. You'll have to assemble the heads and then do a valve clearance check.
The second issue is not a big deal, but does require some machine work and fab/weld up, and that is the water jacket port on the head. One bolts right up, the other side has to be flip-flopped - sorry, it's been a while and I don't recall which is which.
Other than those two, and the obvious head gasket issue as well, it's a fairly straightforward swap.
Yes, you have to use 928 cams (which can be cut to any 944/951 grind), but otherwise pretty straightforward.
FWIW, I would lean toward the turbo head, esp if you plan on boosting it.
Greg
Old Oct 21, 2003 | 02:03 AM
SharkFan's Avatar
SharkFan
Hey Mark,
I say just rip the top off of one of those Euro motors ya got and drop it on a 5 liter block.
Old Oct 21, 2003 | 09:19 AM
Joe Ricard's Avatar
Joe Ricard
Mark, not sure which combo woul have the best flow numbers or give the broadest torque curve.
I mean if the 944 heads flow better will you lose lowend power.
Would it be cheaper to extrude hone you Euro head and skip all the "flip flop" of water inlets.
I say you dyno before and after the 944 swap and let us know the real deal. You know I am only 120 miles from Pensacola I will help test.
Old Oct 21, 2003 | 01:34 PM
Jim Nowak's Avatar
Jim Nowak
Mark,
I have 944 heads on my 928. Give me a call.
