Bosch Connector Repair
Decided to go ahead and repair this one that goes to what I think is the knock sensor. PO had done a pretty bad job. Took it apart and this is what I found. Looks like two wires with the third connecting to the metal sheathing that's wrapped around the other two.
Does this look right?
Yes, there are a few connectors like this (CPS is another) where the braided shielding ensures a clean signal to the computer.
Edited: Oh I see this is an S3, no knock sensor so this is the CPS. I had a similar question about this connector a few months ago.
Just for the record and in case anyone is looking for info in the future. Attached are a few photo's. I used the replacement connectors from Roger. Basically carefully cut away some of the plastic sheathing. Then twisted the exposed metal braid and crimped new connectors. It certainly looks a lot better than the PO job. Just hope it will work.
