Has anyone found any new replacements for the A/C vacuum solenoids? They are NLA but I would like to get some type of new equivalent replacement. They are kind of 3 way whereas they hold vacuum until activated by the head unit to let vacuum flow to the diaphragm but when deactivated release the vacuum to the diaphragm but continue to hold vacuum at the vacuum source.
Have you had one that's actually failed? I've tested more than a few as part of HVAC troubleshooting, and have never found any that have failed on their own.
I've had to replace many of them and the only option was to replace with a known good working one.
Figuring nothing to loose, tried fixing a couple with Wurth brake cleaner. Mike Schmidt (Z) successfully fixed a a couple this way many years ago.
With vacuum on one side, sprayed some in & turned on the 12v. Instant success, before a slow open, now instant.
Bad news, few minutes later tested again only to find now it's completely locked up.
As time & age takes a toll, I suspect we'll need to figure out a replacement?? Might run out of good used ones.
Eric if you have a few bad solenoids why not take one apart to see whats going bad.
That wurth cleaner may be softening the internals and then making the parts inside sticky ,
I would try some silicone spray or WD40
You mean destroy? No way to take them apart without wrecking them. Way ahead of yea...
I went with brake cleaner due to past success by Mike. I have a theory why it didn't work for me and having late night shop regrets.....
I'd be leery of using anything that won't evaporate and I went with the Wurth stuff since it's arguably the highest quality brake cleaner.
3 types of failures I've experienced:
Slow to open. These are just an electromagnet pulling down a piston with a plunger on the tip. With vacuum applied it should be an instant open. Some of these would slowly go down on the vacuum gauge.....that's not going to work.
Doesn't open at all. I tried repeated on/off cycles and reverse polarity. You can hear the "click" but no vacuum change.
They leak. Plug one end, apply vacuum, doesn't hold. About the same rate as #1. I suspect these might still work as they do open "full force" once power is applied.
Why my "cleaning" method might not have worked: I sprayed the sauce in reverse of airflow and possibly knocked off the plunger on top of the piston. I'm not 100% certain of this since two of them I ripped apart the plunger was still attached. Doesn't really explain why the "stuck" or slow ones suddenly worked perfect for a couple of minutes of cycling the piston after spraying in the sauce then suddenly stopped....... I'm a bit baffled since there isn't much going on inside of these.
The magnet function is still working in the disassembled ones. I apply power / ground, insert the piston & I had to use a pliers and a good amount of force to pull it out.
I'm pondering if there isn't some debris in there and when I yank them apart it's too small to catch.
There should be 4 photos, IB seems to have "upgraded" something again, not all loading for me.
I have 1 that either gets stuck or leaks. I have also purchased a used HVAC box to try and use one of them to replace the bad one but they all leak. Also, how do we contact Porsche Classic to request solenoid production.
48 hours later (might have been sooner, that's how long it was between events" they now work.....
So to re-cap chain of events:
1. Any of the solenoids experiencing one of the three failure modes listed above, I put a vacuum on (both end) and sprayed brake cleaner through.
2. All were instantly fixed
3. 10 minutes later they were stuck, I could hear a "click" but no would move through, pressure or vacuum.
I tried them many hours later that day, no go. Two days later (after destroying a couple) decided to play with them again and PRESTO - they all work now.
However.... I would be careful to only have the cleaner flow against the piston so you don't knock off that little silicone "hat". I think this happened to one of the units I broke open.
