If you are adding some sort of terminal end, washers or clamping device to a bolt...for securing purposes...a longer bolt should have been used...to compensate for the loss of threads needed to secure the additional ground strap or washers thickness.
Good luck, with the repair.
Brian.
In fairness I did not add the second ground strap. That was a gift from the PO.
