87 S4 Auto transmission O ring
I am Back...
Search is not my friend tonight..
Changing out tranny filter fluid etc..
There is a white o ring in the plastic nut that goes to the metal tube out the back side of the pan..
Mine only has 1 O ring.
PET from Auto Atlanta and others list the part number as 477321487 and calls out that 2 are required but not shown in diagram.
Cant find a reference in WSW.
So, Does it really get 2 O rings stacked up?
Pricey little suckers too.
Thanks..
So far tonight..
* tensioner filled
* Compressor installed
* alternator installed
* P/S lines connected to pump and belts tensioned
* Started harness connections...(home made harness fits perfect!!)
* Tranny drained and pan cleaned
* Tie Rod ends torqued
* Made new secondary block ground
Sorry for the long post..it has been a while since I made some good head way..
Thanks..
So far tonight..
* tensioner filled
When I ordered the O-ring from Roger he sent me one, and there was only one original to replace. I recommend replacing the O-ring for the Bowden cable. Twist out the yellow fitting and replace the O-ring. Mine was leaking. When I removed the pan I found it hanging on the lever the cable attaches to. The O-ring apparently flattened, hardened, and shrank enough to slip down onto the lever. Not a difficult job and will prevent a common leak. There's a bit of fiddling to get the cable reattached. Using a small mirror on a stick working it by feel it didn't take long to reattach.
Correct one only white O ring.
Hmmmm...I just got a shipment of parts, most of which are to service the A28.07 in the Red Witch.
I ordered a new reservoir and sealing O-ring, item number 41, part number 477321487. The O-rings I received are blue.
I will include a photo.
Seth K. Pyle
Seth K. Pyle
You are correct Sir - was white and now blue - did not know Porsche changed the color or when.
I guess that is there way of making up for the blue hose now being black - blue does matter 8>)
Bowden O ring is ---
O Ring Seal - Control Pressure Transmission Cable - 83 to 86 999 701 664 40
O Ring Seal - Control Pressure Transmission Cable - 87 to 95 999 701 960 40
Wow, that was quick. I called and left a message on your machine, I need the part for an '85 and also the filler cap ring. I hope this will be the end of leaking transmissions...
