73k, Worn Main Bearing
That should be qualified with the statement that this is an analog odo with a history of being broken, so in reality it's TMU.
While it's nice to have gotten vindication for the spiraling out of control engine tear down, it's pretty disappointing to see copper on the #1 main bearing at this indicated mileage. What does this wear pattern say about what's going on in this engine?
Also, should there be this much copper showing on the thrust bearing in a 5spd?
Looks as though you need some root cause analysis here. Did you measure the crank end float as a matter of interest?
The thrust bearing looks well wiped as does your main bearing but as to why is what needs to be determined. Oil pump issue?
Plenty of support around.
Rgds
Fred
Rgds
Fred
I got to the point in the tear down where I was going to replace bearings anyway, so unfortunately I did not check end play. The oil pressure was fine before tear down, lowest pressure was about 1.5 bar indicated in stop-and-go traffic on a sweltering day. Oil pump looked good but had a ton of axial play.
I have also been somewhat concerned about the warnings Greg Brown has given concerning the state of the engine dampers as they age and lose the ability to do what they were intended to. If your oil pressure was satisfactory one wonders if the damper might be a contributing factor?
Rgds
Fred
Was that the pressure at idle or with some revs? At idle it seems a bit low but not that bad. Did oil pressure recover to normal full pressure by the time you hit around 3k rpm?
Rgds
Fred
Rgds
Fred
With the localized damage, damper was on my mind too...
Completely normal thrust bearing....actually pretty nice! Note that the entire surface hasn't worn away the coating. The stock coating on the flanges of the trust bearing is very thin.
There is no soft layer to absorb dirt and particles, like on the faces of the bearings. They get into the "copper" immediately. (This part of the bearing must be hard to control the endplay forces.)
The wear on the front bearing is caused by crankshaft harmonics, in my opinion. The stock dampers had the rubber connector between the two metal pieces get too hard to transfer the harmonics about 15 years ago.
Main bearings used to come out of these engines looking pretty good....I reused many sets.
Now they all look like yours...or worse. The cars that run at higher rpms really beat them up....along with the block and cradle.
Looks like you might have a new customer!
Something we should all be paying attention to before it is too late for the bearing [I suspect].
