Sharkwoofer Re-design - bringing back bass and amplification for the 928
#65
It took a bit longer than I hoped with SITM and a couple other distractions, but I have the enclosure modeled, and it looks like it should fit with plenty of clearance and have a spot-on target volume.
Here is a link to a 3D model showing the enclosure portion of the design. I have the composite part translucent so you can see the driver inside and the relief for the amp connections easier:
http://cloudviewer.spaceclaim.com/e6...6f861d04e.html
Now I need to find someone to machine the foam plug for me so I can test it and make any fit changes, and then send it off for a mold.
Hans
Hans
#67
Hans: If I may make a suggestion - since this post has gotten so long, I recommend starting a fresh thread and have admin put a "sticky" on it when you are ready to take orders.
#69
I havent been able to get the foam plugs machined. My normal source is moving his shop and doesnt have his equipment setup again yet.
If anyone has access to a cnc router that can do surfacing and has at least 5" of Z-travel, the files are ready. I could go old-school and cut them out and shape by hand, but I would prefer not to go that direction.
#73
Super true. However at this point with my amp setup I will just add a second ADS PH15.2 and a AX2e, bridge all the channels and double my output to each channel.
The sharkwoofer has become practically an all in one system. I want to keep my stereo period to the early 90s. Plus $100 is a little easier to justify.
