Life Hacks - Mechanic's edition
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
C-clamp on the old brake pads is a good one for collapsing the caliper pistons for your replacement pads. Most of us know that one I am sure.
Fuse 24 Assassin
Fuse 24 Assassin
Originally Posted by WD40 MSDS Sheet
Swallowing may cause gastrointestinal irritation, nausea,
vomiting and diarrhea.
when changing brake pads, I use a turkey baster (well, I actually use a 600cc syring, but...) to remove some of the brake fluid from the master before pressing the pistons in.
Archive Gatekeeper
The best rubber/seal/hose assembly lube I've seen is P-80 THIX. Water based, no silicone, no oils. Works great.
![](https://webfiles.uci.edu/redwards/public/P80%20THIX%20rubber%20assembly%20lube%204-14-16.jpg)
When installing new spark plugs, I always slip on a 10 -12" pc. of black rubber tubing on the end of the plug, allows you to carefully lower the gapped plug into place and start it with minimal chance of a cross thread. screw it in pop of tubing then tighten properly. this works great on engines with headers in the way , but I use this method always now.
A leaking lipseal [where the lip has age hardened] can be brought back to serviceable life by boiling in a solution of old fashion washing powder [i.e. non detergent] solution for 10 minutes. The process softens the rubber quite nicely so that the seal face will seat correctly once more.
Did this on my Jaguar steering housing seal. Agents said the seal could not be replaced and a new housing was going to cost about $1k. Worked a treat.
Developer
The main ingredient in WD 40, is fish oil. You can eat it with no long term ill affects.
I LOVE this thread! Many good ideas!
Long ago used a trick to remove a pressed in bronze bearing in the end of a crankshaft. It was a guide for the input shaft on a transmission. I packed wheel bearing grease into the hole, and filled the space behind as much as possible, then found a round bar that fit snugly in the hole of the bushing - then just hammer it into the grease packed area - the hydraulic pressure forces the bushing out of the crank end.
why make it so hard.. just get a broad flat screwdriver and pry the pads back against the rotor while the calipers and pads are on the car. then, you remove calipers with pistons all the way compressed and the new pads go back on in a snap!
wanna tune your car.. you dont need a Brake dyno.......you can run the car on jackstands in 4th gear and use the brakes to tune at the target RPM! WOT, apply some brakes find the desired RPM , check mixtures. done!
